Thread: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
Results 1 to 8 of 8
  1. #1 RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    Dec 2012
    london, on
    Can any one help?
    I have a 2008 Pontiac Grand Prix base 3.8L with 120,000km. I started having this fluttering issue as if the engine was starving for fuel or mis-firing at 1700-2400RPM'S when traveling up a incline between 3rd-4th gear (engine is under load). If you press the accelerator far enough the engine performs as it should and accelerates smoothly at 3000RPM'S +. Its very specifc to driving slow on an incline at the specified RPM's. The transmission fluid and filter have been replaced twice so far (I am particular about maintenance). I thought it was the spark plugs and wires so I changed them with stock OEM delco plugs and wires, the symptoms still persist. The engine light has not come on to trigger any DTC's. Has anyone else experienced this symptom before?
    Thanks everyone for their input in advance!
    Jeff
  2. #2 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    u try cleaning the maf and also cleaning the throttle body they had a good problem with the tb getting dirty and then they would run funny...sometimes when you start it does it die and you have to restart it and hit the gas?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    Dec 2012
    london, on
    Ok thank you! I will start with that. I have noticed (even after replacing the plugs and wires) that if I use the remote start it wont start right the first try intermittently. Other than that no I dont find it to stall out much. I will let you know how I make out.
  4. #4 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    Dec 2012
    london, on
    I tried what you recommended and unfortunately it didnt work. I decided to bring my car to the GM dealer which I was not overly looking forward too as usually its a run-around with GM dealers. To my pleasant surprise the service advisor was awesome, she scheduled me in and I brought my car in the next day. Long story short, the problem was the transmission solenoid. They replaced the solenoid and cleaned the valve body. The transmission is working perfectly. Finch GM in London, ON did a great job.
    Jeff
  5. #5 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    Ontario
    ^^ That must've run you a pretty penny.
  6. #6 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    Dec 2012
    london, on
    It was FREE! Covered under Power Train Warranty.
  7. #7 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    high load, low rpms, converter locked.
    let completely off the gas pedal to unlock the converter. ease back into the throttle. it will never happen again.
  8. #8 Re: RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    May 2016
    Lincoln, Nebr
    Sorry to re-new this old thread. My car is doing the same thing jdebus97 described above. Same yr/make/model. Is it likely a transmission solenoid?
    Bio248referenced a converter lock, what the heck is that and could it be the issue?
    I've cleaned the TB & MAF about 1,500 miles ago and it felt like it was better for awhile, but it's still doing it now.
  1. Just spent 1700 dollars!
    By szalajka05 in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 04:18 PM
  2. GTP acceleration flutter....??????
    By jcurrieta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 06:20 PM
  3. engine flutter
    By 98prix in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-24-2009, 11:49 AM
  4. 1700 hp dyno run! Video.
    By GeddyLee in forum Off Topic Discussion
    Last Post: 02-20-2008, 08:49 AM
