Thank you so very very much! I have forwarded the information to my "peeps" to see what they can come up with... so far I gotta give you props because the know it all says ooohhh... that makes since that sounds about right so kudos to you!![]()
What has happened when she cuts off is I'm driving slow down to go around a curve or turn and the idle spazzing starts jumping from 0 to over 1 rpms then on the down spike she dies... I throw it in park and begin to start. It's taken a couple of tries and usually success comes from me listening to the turn over and hitting the gas hard just right then I can go. It's not the map sensor ( God knows I know about those!).
I still think the snout needs servicing... I am positive no one serviced it before I got it and it still sounds like "poo" I do know the tensioner is loose for the supercharger belt but of course I'm told to just drive it... it's ok so...![]()
But thanks again and I will see what I can do from here. If you have any other info please share!![]()
