Thread: pulley/belt squeak
Results 1 to 10 of 10
  1. #1 pulley/belt squeak
    Apr 2013
    Salt Lake City
    I have a 2008 Pontiac Gxp and am trying to diagnose an annoying squeak. I'm just trying to get some help with the easiest way of figuring out what is making a noise. Is there something I should try first to test it. also it only does it when you barely start the car. It doesn't seem like it's doing anything to it performance the noise is just annoying. Kind of OCD about the way the engine sounds. Thank you for your help
  2. #2 Re: pulley/belt squeak
    take the belt off, then spin all the idlers and tensioners pulleys my hand, if you find one thats not smooth spinning, it should be the squeak.
    you can also take the belt off, then start it up for a minute, if the sound is gone, its in the belt area for sure. dont run the car long with no belt, your water pumps not spinning so it can over heat.
  3. #3 Re: pulley/belt squeak
    Apr 2013
    Salt Lake City
    awesome I definitely appreciate it thank you very much. I will give that a try later today or tomorrow and reply and let you know if that worked. Thank you again
  4. #4 Re: pulley/belt squeak
    GTP Level Member joshv's Avatar
    canada
    my belt squeeked for the longest time, i found a 2 foot crack down the middle of it :s
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  5. #5 Re: pulley/belt squeak
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by joshv View Post
    Sounds like my ex-wife.
  6. #6 Re: pulley/belt squeak
    Apr 2013
    Salt Lake City
    hell yeah I'll make sure to take a look at that as well thank you
  7. #7 Re: pulley/belt squeak
    Sep 2012
    Cedar Rapids, Iowa
    I have a 2002 GT but I had the same problem. Took off the belt and rotated each one. Turned out to be the power steering pump. Put some oower steering fluid in and it works great
  8. #8 Re: pulley/belt squeak
    Apr 2013
    Salt Lake City
    hey thank you everyone for your help. Ended up just needing some belt dressing lol. Thank you very much for the help though
  9. #9 Re: pulley/belt squeak
    time for a new belt, that stuff dont last but a day or two. you can try cleaning it with warm soapy water and a scrub brush.
  10. #10 Re: pulley/belt squeak
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Chances are if you applied belt dressing, you applied it to the smooth surface of the belt. If this is true you narrowed your problem down to the smooth surfaced pulleys. Follow scotty's suggestions on hand spinning the idlers. Also look to see if the belt is tracking properly. A worn tensioner or idler pulley can cause the belt to track at an angle causing the belt to slide resulting in a squeak.
  1. Alternator Pulley Squeak
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 06-17-2012, 08:39 AM
  2. Pulley Squeak
    By Adidasdude1989 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 07:25 AM
  3. Perpetual belt squeak
    By Coogles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 09:07 AM
  4. 3.4 pulley squeak
    By pacoflyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2008, 12:15 PM
