Thread: 98 gtp with 97 motor ?????
Results 1 to 12 of 12
  1. #1 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    I have a 98 gtp but when running the vac lines correct figured out the motor is a 97 my dic isn't working only flashing 0 in everything can how do I get the dic working in this situation any and all info is appreciated thank u
  2. #2 Re: 98 gtp with 97 motor ?????
    DIC has nothing to do with the vac lines or the motor year.
    Did you swap the 97 pcm in ? You shouldn't have.
  3. #3 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    No I have both a 97 and a 98 PCM
  4. #4 Re: 98 gtp with 97 motor ?????
    The only differences in the motors is a vac tree on the front of the SC. Which you can cap off with 3 caps
  5. #5 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    The 97 PCM is hooked up now but I have a 98 or 99 maybe even 2000 model PCM
  6. #6 Re: 98 gtp with 97 motor ?????
    Heck, you might only have a 97 charger.
  7. #7 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    What about the dic any info to get that working or will capping that off fix it
  8. #8 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    The PCM that's on it now looks like a 97
  9. #9 Re: 98 gtp with 97 motor ?????
    I've seen some 98s with vac trees.
  10. #10 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    Wouldn't that make the motor a 97 ?? Another question shifts perfect in all her except for when shifting from 2 to 3 have to kinda get the rpm up but after third shifts fine in other gears
  11. #11 Re: 98 gtp with 97 motor ?????
    A 97 pcm is pinned totally different than a 98. Put the pcm for the year of the car in the car. Use the wiring harness for the year of the car as well.
  12. #12 Re: 98 gtp with 97 motor ?????
    Mar 2013
    Charleston
    Ok thank you sir
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  3. motor out what do i need for top swap off old sc 3800 motor to a n/a 3800 motor
    By 98regal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2012, 06:48 AM
  4. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  5. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
