Thread: ignition wire power
Results 1 to 7 of 7
  1. #1 ignition wire power
    Dec 2012
    san pablo,ca
    I have a 2001 pontiac grand prix 3.1 motor the problem I'm having is it will not start with you turning the key in the ignition but if you jump the starter it will start and I'm not getting power at the purple wire from the ignition switch.
    I live here. DirtDog's Avatar
    Jun 2012
    Im not for sure if these cars have a starter Solenoid, but in a friends truck his wouldn't start but I was using a volt meter and we bypassed the solenoid and it would start. If ur car has em I would try that. Their pretty cheap
    Sent from my pager using Morse code. ... .. ... ....
    Jun 2012
    Also question: does the engine turn off when u turn the key off?
    2: when u turn the key all the way to the start position do ur interior electronics turn off like normal then back on when u let off the start position
  4. #4 Re: ignition wire power
    Dec 2012
    san pablo,ca
    Yes when starter jumped and engine running you can turn the engine off fine and when trying to start it with the key the inside light will go out like you starting it but its no power coming from the purple wire from ignition.
    Jun 2012
    This would be where I would start at. Cheap and easy to replace
    http://www.oreillyauto.com/site/c/de...=starter+relay
    Then if that doesn't fix it I would say ur ignition switch is bad. But try that first I've seen a couple in friends cars go bad...but its not very common
  6. #6 Re: ignition wire power
    Dec 2012
    san pablo,ca
    Ok I will try it tomorrow and I will let you know
    Quote Originally Posted by marines542 View Post
    BWD R3109 - Relay - Multi-Use | O'Reilly Auto Parts
  7. #7 Re: ignition wire power
    Dec 2012
    san pablo,ca
    I found the problem it was a bad ignition switch
  1. Ignition on wire in the engine bay that wont require a relay?
    By Tengis in forum General Tech Discussion
    Last Post: 06-24-2011, 02:26 PM
  2. Engine Bay Ignition Wire?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2011, 02:24 PM
  3. melting wire from ignition switch
    By Bronze in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-27-2010, 08:46 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
