Thread: ignition wire power
Results 1 to 7 of 7
  1. #1
    I live here. DirtDog's Avatar
    Jun 2012
    This would be where I would start at. Cheap and easy to replace
    http://www.oreillyauto.com/site/c/de...=starter+relay
    Then if that doesn't fix it I would say ur ignition switch is bad. But try that first I've seen a couple in friends cars go bad...but its not very common
    Sent from my pager using Morse code. ... .. ... ....
  2. #2 Re: ignition wire power
    Dec 2012
    san pablo,ca
    Ok I will try it tomorrow and I will let you know
    Quote Originally Posted by marines542 View Post
    BWD R3109 - Relay - Multi-Use | O'Reilly Auto Parts
  1. Ignition on wire in the engine bay that wont require a relay?
    By Tengis in forum General Tech Discussion
    Last Post: 06-24-2011, 02:26 PM
  2. Engine Bay Ignition Wire?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2011, 02:24 PM
  3. melting wire from ignition switch
    By Bronze in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-27-2010, 08:46 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
