Thread: Intake manifold gasket replacement now high idle
Results 1 to 14 of 14
  1. #1 Intake manifold gasket replacement now high idle
    Jan 2013
    georgia
    I replaced my lim gaskets due to a coolant leak and now i have a 2500-3000 rpm at idle could i have possibly cracked the lim when i was reassembling the engine??
  2. #2 Re: Intake manifold gasket replacement now high idle
    Jan 2013
    georgia
    this is on a 2000 pontiac grand prix 3.1
  3. #3 Re: Intake manifold gasket replacement now high idle
    Omaha, NE
    You more than likely have a large vac leak.
    With the car on and in park, spray some starter fluid around where the lim goes to the block and where the uim goes to the lim. Then try all the vaccum lines. If the idle changes you have a vac leak.
    Double check your fluids again too so you can be sure they aren't mixing again.
  4. #4 Re: Intake manifold gasket replacement now high idle
    Sounds like a vacuum leak to me.
  5. #5 Re: Intake manifold gasket replacement now high idle
    Jan 2013
    georgia
    so is a cracked intake pretty much out of the question?? thanks for your help
  6. #6 Re: Intake manifold gasket replacement now high idle
    I wouldn't think you would crack it unless you really cranked on it. Did you torque it? And did you use locktite on the bolts?
  7. #7 Re: Intake manifold gasket replacement now high idle
    Omaha, NE
    Do what I said to look for vac leaks. If you find one, look at where it came from to find out if the manifold is cracked.
  8. #8 Re: Intake manifold gasket replacement now high idle
    Jan 2013
    georgia
    Well i have cracked the upper intake manifold.I guess my torque wrench is trash. Now im going to tear it back down to see if the lower is cracked. Is there any good torque wrenches in the 100.00 range out there??
  9. #9 Re: Intake manifold gasket replacement now high idle
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    you made sure you tightened that good huh?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by coreyrcflyer77 View Post
    Are u sure its cracked? Pics maybe
    I would still do this
    Sent from my DROID RAZR using Tapatalk 2
  11. #11 Re: Intake manifold gasket replacement now high idle
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    you likely read the torque specs wrong. torqued in ft. lbs. when it called for inch. lbs.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  12. #12 Re: Intake manifold gasket replacement now high idle
    Jan 2013
    georgia
    Well found out tonight that I cracked the lower intake too. Good thing I got the lower and upper when I was at the used parts place. Is the torque specs in the chiltons manual what yall go by?? As far as the lower intake bolts is loktite all I need to use on them or do I need some sealent also?? thanks a lot everyone.
  13. #13 Re: Intake manifold gasket replacement now high idle
    I never torque those bolts down, the bolts can snap in some cases.
    Just get them all tight and go around and snug each one up just a little. I don't see a need to use a any sealant either. Some say otherwise.
  14. #14 Re: Intake manifold gasket replacement now high idle
    I use sealant since some of the bolts go into coolant passages
  1. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  2. Engine want start after intake manifold gasket replacement
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2012, 09:04 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. High idle after intake replacement,need help quick
    By christopher8911 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 04:08 PM
  5. Manifold Gasket Replacement... Questions
    By brownb66 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 10:54 AM
