I have a 98 GP GT with the 3800. Car ran great but had an issue with the lower intake leaking onto the block, so I decided to do the intake replacement. I ordered the "gm shure fix" upper composite intake, gm lower aluminum intale gasket set, new fuel injector seals, new 180 thermostat w/seals, and new heat senser. Install wasn't difficult at all and all bolts were installed as directed per instructions. After I finished installation I drained and changed radiator fluid, and engine oil. When I started the engine the car shot up to 3000 rpm then rested at idle around 1200 rpm. Engine stays reved. I can press the accelerator and the car will take the gas, it just seems to be ideled up high. Everything was cleaned and install was as instructed. I did clean the throttle body before I re-installed it to the new intake. No codes are being shown and im not shure what i should do to try to fix the problem. Any ideas?
