Thread: Coolant leak in number 2
Results 1 to 3 of 3
  1. #1 Coolant leak in number 2
    Dec 2012
    Cocoa, Florida
    I have a 02 Grand Prix GT with a 3800 Series II motor. i few weeks ago it overheated and both upper and lower intake gaskets were damaged so i bought the kit $79 and some change and put them both in. waited for the RTV to cure and fired it up started right up. the engine is shaky and there was steam coming out of the exhaust no CEL was on at first let it run 10-15 mins then it started flashing i am aware a flashing CEL is a misfire in one or more cylinders which i tested and is the number 2 cylinder that i know of right now............. after replacing the upper intake plenum gasket throttle body gasket all fuel injector gaskets.... ETC the kit basically came with all gaskets that are on the upper half of the engine excluding the head gaskets. what in HELL is causing the coolant to leak into number 2? this car gets me to and from work everyday so an intelligent answer from somebody that has had this exact problem before would be more helpful rather than guessing if you havent had the problem. Thank you..!
    and a side note i have had more than one of these motors....... so i am quite familiar with them
    97 Bonneville SE
    99 Bonneville SE
    02 Grandprix GT
  2. #2 Re: Coolant leak in number 2
    Dec 2012
    san pablo,ca
    My guess it could maybe be a blown head gasket.
  3. #3 Re: Coolant leak in number 2
    Dec 2012
    Cocoa, Florida
    I'm doing compression tests right now here is where I got
    #1 105Lbs
    #2 185Lbs highest pressure on the cylinde with coolant leaking in it
    #3 150Lbs
    #4 100Lbs
    We haven't made it to #5 or #6 yet but will post the results after we're done with the test
  1. coolant overflow tank GM Part number anyone?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-30-2012, 06:48 PM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. GM part number f/coolant elbows
    By sav24dl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2011, 12:47 PM
  4. Coolant Leak, But Where??
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 10:46 PM
  5. 99+ coolant bottle GM part number
    By GRAND98 in forum General Tech Discussion
    Last Post: 09-01-2011, 12:00 AM
