Thread: New to site, new to the gtp, already have a problem :/
Results 1 to 5 of 5
  1. #1 New to site, new to the gtp, already have a problem :/
    Dec 2012
    Ohio
    Hi all! Can't figure this one out on my own so I'm recruiting some help! I just bought a 97 Grand Prix GTP. The previous owner has modded it A LOT. All the way from neons to 10lb nitrous bottle. My check engine light came on and it started running like poop (ran like the MAF went bad) So I took it to Auto-Zone and had them run the codes. I got 3 codes at once: p0705;transaxle range switch fault. p0171;trim fuel bank one condition. p1200;fuel injector circuit. I debunked the MAF as being bad, it does not seem to be the issue. I'm leaning towards a malfunctioning fuel injector or a vacuum leak. Short of testing all theories until I figure it out I thought I would hit the forums and see if anyone else has had these exact codes at once and how they fixed the problem! Thanks for the help in advanced!
  2. #2 Re: New to site, new to the gtp, already have a problem :/
    vacuum leak. where are you located in oh?
  3. #3 Re: New to site, new to the gtp, already have a problem :/
    Dec 2012
    Ohio
    Chillicothe! And vacuum is my biggest suspect
  4. #4 Re: New to site, new to the gtp, already have a problem :/
    List of mods?
  5. #5 Re: New to site, new to the gtp, already have a problem :/
    Dec 2012
    Ohio
    I found the problem! One of the fuel injectors was unplugged. (Insert le sigh of relief) the bracket holding the plug onto the injector is broke. But I got er fixed up! As for a list of mods it's quite the list so I'll post a new thread and delete this one. Thanks guys!
  1. New to this site, might have a big problem!
    By BigD09 in forum Introductions/Noob Questions
    Last Post: 11-12-2012, 03:42 PM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. new to site...have a problem hope you can help!
    By bbygrl75 in forum Introductions/Noob Questions
    Last Post: 03-12-2010, 03:21 PM
  5. new to the site
    By slammed2000gt in forum Introductions/Noob Questions
    Last Post: 02-28-2010, 05:13 PM
