Thread: 2004 GT2 Gas Hand/Tran/ABS
Results 1 to 3 of 3
  1. #1 2004 GT2 Gas Hand/Tran/ABS
    Dec 2012
    Austin
    My gas hand moves up and down as i drive up a hill or down a hill or even take off fast it seems like it moves with the gas any one know what i need to do to fix also my tran jreks when i drove it for a while but when i turn it off and turn it back on it stops any ideas and last my abs light comes on ever once in a while
  2. #2 Re: 2004 GT2 Gas Hand/Tran/ABS
    1. Possible fuel level sendor arm in the tank.
    2. Time for a service? Or scan the trans for codes. Clean the TB and MAF sensor really well with the right cleaners.
    3. Get it scanned with a scanner that can read ABS codes, its either a wheel bearing/wire issue or the ABS module.
  3. #3 Re: 2004 GT2 Gas Hand/Tran/ABS
    Dec 2012
    Austin
    the trans has been service it only do it some times its not a every day thing like i drove from austin to huston and it ran great but on my way back it did it like 2x i pulled over check fluid level was good then i got back on the road and it stop it shift it just fine
  1. tran problem
    By jimjackson in forum Introductions/Noob Questions
    Last Post: 11-05-2012, 09:41 AM
  2. About to buy '07 tran for my '99 GTP ???
    By 90210GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-22-2011, 08:44 AM
  3. 97 gtp tran problem
    By ibanez0110 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 01:37 PM
  4. 98gtp Tran Swap! (pics)
    By FoSHO99 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-01-2008, 07:04 PM
