Thread: having a problem help please
Results 1 to 20 of 32
  1. #1 having a problem help please
    GTX Level Member STEVEGTX's Avatar
    Oct 2012
    Sleepy Hollow, Illinois, United States
    Ok I have a 98 gtp having problems with car thinking its my alternator bearings? Loud squeak had lights dim also having problems with car rpms jumping up and down every now and no codes. when I was driving today it was not to bad just loud squeak when I let off the gas to cost it stopped and when I went to take turns felt like power steering was cutting out. Changed plug wires mafs that's all I can think of right now
  2. #2 Re: having a problem help please
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    get battery and alternator checked at your local parts store...they usually do it for free
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: having a problem help please
    Oct 2012
    Just replace the battery few mouths back sorry forgot to say that
  4. #4 Re: having a problem help please
    Jul 2012
    if the alternator is going...won't be long b4 your battery is used up...I'd gett it checked ASAP
  5. #5 Re: having a problem help please
    Oct 2012
    I have 1 of a 97 GTP them parting out right now I'll switch it out tomorrow morning
  6. #6 Re: having a problem help please
    Oct 2012
    could it also be my supercharger going bad how could i tell between the two? i dont have alot of money right now and i think the other alternator is bad it squeaks when i spin it
  7. #7 Re: having a problem help please
    Superchargers dont just go bad.
    I'd look into an alternator issue if you are having the lights dimming.
  8. #8 Re: having a problem help please
    Oct 2012
    Well found out it was my tensioner pulley went bad replaced it today but still having issues with rpm going up and down thinking the supercharger needs new bearings though just to be safe thinking my boost bypass valve is not working when I'm in boost my car idle goes up and down
  9. #9 Re: having a problem help please
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Bad blower bearings and BBV will not cause spikes in the RPM.
    Bad BBV will cause a loss of a boost when going WOT.
  10. #10 Re: having a problem help please
    i broke vac line on my sc doing my lim job, the idle was jumping up and down, like the car had a cam. i sprayed carb cleaner, and found the broken line in seconds, when the carb cleaner hits the broken line, the rpm's will jump up.
    you do this with the car running.
  11. #11 Re: having a problem help please
    Oct 2012
    Going to try to test again my throttle body gasket suck through once and it did the same problem I'm going to check that out also tomorrow
  12. #12 Re: having a problem help please
    Oct 2012
    Ok changed my tb around today feels like that was part of the problem but when I hooked it back up I got a code p0122 tps bad when I went to take off it wouldn't shift untill I hit 35 so I changed it out still having the problem why would that happen?
  13. #13 Re: having a problem help please
    check the wires to the plug for cracks or breaks in the insulation look right at the ends, and bend the wires to see if you see and breaks, if so that could be your problem, you been handling them so one could have broke, or the cracks got to it causing dry wire. bad wires, with throw the same code as a bad sensor.
    make sure you got them plugged in the right place, kinda hard to do, but well it happens. lol
  14. #14 Re: having a problem help please
    Oct 2012
    Yeah I checked them they seem to be fine I'll double check them tomorrow if I was to replace the wires how would I go about that
  15. #15 Re: having a problem help please
    you can buy a new pig tail for any sensor on the car, cut the old one off strip the wire back till you get to shiny clean copper, and solder and shrink wrap the connections. new pig tail cost around 10 bucks, or cut one off a junk yard car.
    soldering is very easy, search youtube for a lesson. 10 dollar soldering iron, and a 3 dollar tube of flux core solder, another 5 for shrink tubes.
  16. #16 Re: having a problem help please
    Oct 2012
    Alright ill look tomorrow at it hopefully it will be that
  17. #17 Re: having a problem help please
    being that the wires cook over the exhaust cross over pipe, its possible.
    i had to replace my maf and iat pig tails. funny thing is, after i put them on i have the solder and tubes left. my friends charger cord was chewed in half by his cats, im like "i can fix that", and i did, and it worked lol saved him a easy 20 for a new one.
  18. #18 Re: having a problem help please
    Oct 2012
    Alright ill look tomorrow and buy a plug and change it out
  19. #19 Re: having a problem help please
    Oct 2012
    Battery is brand new I got a code now for my tps changing the plug becuse it has a short I guess
  20. #20 Re: having a problem help please
    Oct 2012
    Alright so got a volt tester today and put it in the tps only one wire lit up is that right?
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Ps problem
    By Jen Jones in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2012, 10:42 PM
  4. Ac problem
    By Kenny75k in forum General Tech Discussion
    Last Post: 07-22-2010, 06:38 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
