Thread: having a problem help please
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #1 tps volts?
    GTX Level Member STEVEGTX's Avatar
    Oct 2012
    Sleepy Hollow, Illinois, United States
    Having a problem now with my tps changed it out 2 times and still getting the code p0122 car won't shif until I hit 35 it might be a short in the wire got one of the things to test it 1 out of 3 lit up figure one is ground? Not sure but should it light up on all of them? Changed the plug with a good one I had and still same problem
  2. #2 Re: tps volts?
    Oct 2012
    Could I have put the tps in wrong?
  3. #3 Re: tps volts?
    Not likely. However Scottydoggs will tell you all about how the wiring over the exhaust will go bad and you may have an issue in the wiring and not the sensor.
  4. #4 Re: tps volts?
    we already went over that one Bill in his other thread.
  5. #5 Re: tps volts?
    I feel a merge about to happen.
  6. #6 Re: having a problem help please
    Oct 2012
    Yeah I'm going to try and get a new wiring harness today for a 98 to match the motor and computer I have ( I have the 97 body and harness right now) and if I change that would that maybe help?
  7. #7 Re: having a problem help please
    The pcm is physically different and the pinouts are different.
  8. #8 Re: having a problem help please
    If you put a 98 harness in a 97...you can't use your pcm.
  9. #9 Re: having a problem help please
    Oct 2012
    I have a 98 one that's tuned for my car when I put the motor in I forgot to change it so I'm using the 97 for now but I wanna get my computer in its from dh I think they don't make them anymore
  10. #10 Re: having a problem help please
    Oct 2012
    Any ideas what I should do
  11. #11 Re: having a problem help please
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  12. #12 Re: having a problem help please
    Oct 2012
    How hard is it to change out the harness just the front peace when my car motor is still in?
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Ps problem
    By Jen Jones in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2012, 10:42 PM
  4. Ac problem
    By Kenny75k in forum General Tech Discussion
    Last Post: 07-22-2010, 06:38 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
