Hello and welcome to the forum! If its just your upper coolant elbo and not the intake gasket leaking I reccomend these coolant elbos - Aluminum Coolant Elbows #ZZ-ALCE. They are aluminum and work great I had several problems with the crappy Orielys elbos I went through 3 elbos in the past year until I bought the new ones. The process isnt to bad just pull the serpintine belt off and the alternator and then remove the tensonor with 3 bolts pretty strait forward IMO also Id flush your coolant system while your at it. Good Luck!
