2002 GP
I was leaking coolant on the ground from the passenger side of engine. I pressurized the system to see where it was leaking. The elbow was for sure leaking.
However, while I had pressure on it, I noticed that it was also leaking coolant on the other side of the engine around the flange where the air filter "stove pipe" bolts to the upper intake. Coolant leaked from nowhere else that I could see or hear. My oil is not milky and the car runs great, except for the elbow leak.
Do I have a bad upper intake gasket?... or is that some other gasket? I'd hate to remove and replace the upper intake gasket if I don't need to.
