Hello, from Florida.
I am the proud new owner of a 1998 Grand Prix GT, with the 3800 Series 2. Has around 196k miles on it. Runs great, just needs a motor mount.
It's also having a weird cooling problem. The radiator fans come on immediately after starting the engine, and they stay on until I turn the engine off. However, the temp gauge on the dash will warm up (it takes a while to do this) and hover around the 210 mark for a few minutes, then it will slowly creep up around 240 or so. Every now and then, it may reach 250 or so when stopped in traffic. The temp light hasn't come on yet.
According to the previous owner, he's installed a new water pump, new thermostat, and new intake manifold (is the intake manifold underneath the fuel rail? If so, it has a lot of corrosion on the top of it). The cooling system has not been flushed recently. The top radiator hose feels hot to the touch, but I haven't thought to feel the bottom hose to see if the water is circulating in the radiator correctly. I noticed that the small hose going from the radiator fill neck to the coolant reservoir was over the driver's side rail, and was being restricted when the hood was closed, so I re-routed it under the rail.
I've done a quick search in this forum, and someone with a similar problem mentioned it may be a coolant temperature sensor. Personally, I feel that a radiator flush may be in order, since the filler cap is a bit dirty on the bottom, and the coolant itself looks dirty.
Any thoughts, etc, would be greatly appreciated.
