Thread: Difference in headers between gtp and gt?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Difference in headers between gtp and gt?
    Mar 2012
    NC
    Oh goodness...I ran a 4t60 top swapped without issue for many miles. It's all in how the trans was taken care of. Guy asking silly header question, do not listen to the 4t60/4t65 BS. Run what you got til you grenade it. /END
  2. #22 Re: Difference in headers between gtp and gt?
    Nov 2012
    Katy, TX
    thanks a lot i just read the whole thing a lot of info
  3. #23 Re: Difference in headers between gtp and gt?
    4t60 has the strong chain too.
  4. #24 Re: Difference in headers between gtp and gt?
    Aug 2011
    Kenosha
    Since were on the subject of transmissions ill try here before making a new thread. When I make a hard left turn my transmission will act as if I shifted into neutral. And when I start going straight it will act normal again. If I give it gas in the turn the engine rpms will shoot up and when the car straightens out it will take off (like dumping the clutch in a manual car) Some people have told me this is a sign of a failing diff. Is that right?
  5. #25 Re: Difference in headers between gtp and gt?
    is the fluid low? cause low fluid will also do that.
    Aug 2011
    Kenosha
    That's the first thing I checked. I'm pretty mechanically inclined. But automatic transmissions scare the hell out of me.
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. What's the difference?
    By BabyGrandPrix in forum Engine
    Last Post: 07-12-2012, 10:13 AM
  3. Difference in NA s1x and SC s1x cam
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2012, 07:49 PM
  4. headers difference
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2012, 09:37 PM
  5. Difference in M90
    By jakeb157 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2012, 04:22 PM
