Thread: headers difference
Results 1 to 8 of 8
  1. #1 headers difference
    May 2008
    Winnipeg, MB
    stock headers are the same regardless if its supercharged or not? as in the s/c engine uses the same headers as the n/a engine
    2007 Pontiac Grand Prix
  2. #2 Re: headers difference
    Omaha, NE
    That is correct as far as I know.
    I have one set of each and they look to be completly identical.
  3. #3 Re: headers difference
    Stock gp's don't have headers they have exhaust mainfolds
  4. #4 Re: headers difference
    Grand Rapids, MI
    they do in fact be the same. and the stock manis hardly flow well enough for the s/c engines at that.
  5. #5 Re: headers difference
    GTP Level Member AjL227's Avatar
    IL
    Yes, all 3800 Series II and III exhaust manifolds are all the same.
    Actually, the stock manifold is considered to be a header, because of its tubular log style.
    That is why, in California you are allowed to put on aftermarket headers that comply to the EPA.
    Of course, I do not know of any that comply anyway, so it doesn't matter.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  6. #6 Re: headers difference
    May 2008
    Winnipeg, MB
    how much of a difference would sd headers make on a na motor with hv3, er rockers, cai?
  7. #7 Re: headers difference
    less wheel spin, more pull above 4000 rpm.
    Tires might chirp a little then hook and away you go.
    If you have half decent tires, which I didn't at the time, then you might just hook right away.
  8. #8 Re: headers difference
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    if you do all that you should get a tune. I did a 91 octane tune and its a huge difference i cant wait till i get a HV3 and PLOG, just got my 2.5'' downpipe(ppl say get 3'' but it was CHEAP) today but wont install it till i got all 3 parts, once I get all 3 parts installed im gonna get a quick retune and should have a nice peppy car untill turbo.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. any difference?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-03-2010, 07:10 PM
  3. any difference?
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 07-07-2010, 10:03 PM
  4. Difference between GTP and GXT... is there one?
    By kjclawson in forum General Tech Discussion
    Last Post: 08-09-2009, 12:34 PM
  5. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
