Thread: Having problem chasing down Random misfire
Results 1 to 12 of 12
  1. #1 Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    I have a 2002 Pontiac Gran Prix GT with 144,000 miles.Just replaced cat and coil pack and maf and also drive belt.Had Advance check batt and alternator ok.Check engine light flashing then goes solid when at stop or idle.Spent a lot so far and need answers before I break the bank.Can someone help me? Thanks
  2. #2 Re: Having problem chasing down Random misfire
    Apr 2009
    Fort Worth TX
    What are the codes?
  3. #3 Re: Having problem chasing down Random misfire
    Change your plugs and wires?
  4. #4 Re: Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    Code is po0300 and changed wires and plugs last summer
  5. #5 Re: Having problem chasing down Random misfire
    Apr 2009
    Fort Worth TX
    Have you changed the motor/tranny mounts?
  6. #6 Re: Having problem chasing down Random misfire
    What did you change the plugs/wires with for replacements. Brand name and or model on the plugs please.
  7. #7 Re: Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    It was done by Goodyear shop and looks like plugs are ac deco and wires look ok as I pulled off to check and pulled plugs and they were not fouled, they looked good to me
  8. #8 Re: Having problem chasing down Random misfire
    My plug wires were a year old Autolite Pro's. Yet they were touching something in a way that allowed an arch to happen. Brand on your wires?
    Most common issues with misfires is plugs/wires which is why I'm concentrating on them.
  9. #9 Re: Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    The car started acting funny weeks ago like bad hesitation and miss especially on up hill. I thought bad gas and added fuel system cleaner after replacing fuel filter. Progressively worse as loss of power to point of just putt putting along. Will make it up to speed limit but when slow down to stop it wants to die but give it gas and ok. It will idle at times ok but then you feel miss and shakes car. Other things done in last six months is replace water pump because overheating issue and thermostat replace too.Just put on at a garage a Walker cat that was a exact fit replacement. Mechanic said needed MAF too so I did. Replace coil too no better. I am now officially a bonafied nut case .... This really sucks
  10. #10 Re: Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    Oh yeah check engine still on but now flashing at speed but stops and just stays lit at stop
  11. #11 Re: Having problem chasing down Random misfire
    May 2012
    Lexington,Kentucky
    I don't know and I didn't ask as I was in Goodyear for tires and asked to have tune up, I do know that plugs are AC Delco because I pulled them to check
  12. #12 Re: Having problem chasing down Random misfire
    GTP Level Member 1ATony's Avatar
    mass
    If you have the code scanned they'll point you in a direction. Once you get the code do a search on Google or post here, and we'll help you out.
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  1. GTP random misfire/hesitation
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2013, 09:43 PM
  2. Random Misfire
    By SamGT in forum General Tech Discussion
    Last Post: 01-06-2012, 07:20 AM
  3. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  4. Random Misfire
    By BlackSun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 12:22 PM
  5. Random Misfire
    By Diegogrande in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 10:18 AM
