Ok, I'm new to GPF so don't bash me too hard.
I've got a 2002GTP with minor mods (3"DP no cat., MSD coils, MSD 8.5mm wires, and AC Delco Irridium plugs, along with a CAI) Recently I had a bad misfire under heavy acceleration, around 3-4k RPM. It would only miss a few times, then accelerate like normal, so I went and replaced the plugs (which had marks on the outside porcelain) with Autolite 104's. The car wouldnt Idle at all, and didnt want to run. So i put the old plugs back in, and it ran Perfectly, no misfire at all or anything.
Then later that day, I went to pass a truck (50-75) and i got a horrible hesitation/misfire. The car bogged horribly, and felt like it was starved for fuel.
Replaced the fuel filter, and checked the pressure at the rail, 50psi.
Checked vacuum, pulling about 20psi.
Any idea what it could be??
