Thread: Hello & help wanted.
Results 1 to 7 of 7
Hood95 Hello & help wanted. 03-28-2011, 09:46 AM
tayl5645 Re: Hello & help wanted. 03-28-2011, 10:12 AM
MoarkatsINmuhtrailer Re: Hello & help wanted. 03-28-2011, 10:26 AM
tayl5645 Re: Hello & help wanted. 03-28-2011, 10:28 AM
MoarkatsINmuhtrailer Re: Hello & help wanted. 03-28-2011, 10:35 AM
Hood95 Re: Hello & help wanted. 03-29-2011, 08:01 AM
Bio248 Re: Hello & help wanted. 03-29-2011, 08:11 AM
  1. #1 Hello & help wanted.
    Ipava, IL
    I am new to the forum and in need of some technical assistance. I have a 2002 GT (not supercharged) and I really like it, but it has developed an annoying sound in the front end. It is not from tire noise or the tires not being balanced properly & it is not engine related (you can put the car in nuetral & shut the engine off as you are moving and the sound is still there). I don't think it is the wheel bearings either. Could it be something in the drive axles themselves? Any help would be awesome! Thanks!
  2. #2 Re: Hello & help wanted.
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    welcome. you might be better putting your question in the tech section as you will get more views
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: Hello & help wanted.
    Ohio
    wat kind of sound is it?
  4. #4 Re: Hello & help wanted.
    Jul 2010
    Michigan
    And honestly with a car rolling and a prominent sound that is constant and gets louder with speed sounds like a wheel bearing.
    2005 GTP Grey
  5. #5 Re: Hello & help wanted.
    Ohio
    Quote Originally Posted by tayl5645 View Post
    this^ and it would be of more help to know what kind of sound
    for example: popping, grinding, is there any vibration?
  6. #6 Re: Hello & help wanted.
    Ipava, IL
    No popping or grinding. Talked to a mechanic friend and he seems to think it is the CV shaft. He said they're not too hard to replace and relatively inexpensive so I thought I would start there. Sound plausible?
  7. #7 Re: Hello & help wanted.
    sounds possible. normally a problem with the axles you'll see the CV boots busted and grease flung all over the place and/or noticeable vibrations. normally a groaning/grinding sound is wheel bearings. they are known to go bad on these all the time, especially if you get cheap ones.
  1. Just wanted to say hello
    By David GXP in forum Introductions/Noob Questions
    Last Post: 10-13-2010, 01:35 PM
  2. Just wanted to say Hi
    By GP_Princess in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 09:08 PM
