Thread: belt problem
Results 1 to 5 of 5
  1. #1 belt problem
    browad
    what tool is required to remove the belt on the 2007 pontiac grand prix gxp
  2. #2 Re: belt problem
    a socket wrench. I cant rememeber the size. Its a tensioner system, so you need to lift up the tensioner and slip the belt off.
  3. #3 Re: belt problem
    Michigan
    Yeah you might have to carefully use wrench with a cheater (did I just say that) to sneak in there. 15mm.
  4. #4 Re: belt problem
    Charles City, IA
    Probally need to rent a serpentine belt tool for the gxp there is no room on the front of the engine.
    SMGPFC Two Nipple General
  5. #5 Re: belt problem
    GTX Level Member Deimos's Avatar
    iowa
    ehh go to sears and spend 60 bucks on the racheting kd tool set I bought mine and love it more than my snap on racheting belt tool
  1. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  2. Belt noise when wet
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2010, 01:10 AM
  3. 3.4 belt
    By xsvtank in forum General Tech Discussion
    Last Post: 05-31-2010, 12:27 PM
  4. Running a GTP without belt?
    By Black18Ice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 12:51 PM
  5. Problem installing SC Belt
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:44 PM
