Thread: Clicking from front end when making right turns
Results 1 to 8 of 8
  1. #1 Clicking from front end when making right turns
    Nov 2010
    Villa Ridge. Mo
    There is a clicking noise coming from the front end when I make right hand turns. Put on new Cv axles, brakes, rotors, hub bearings. Any body have any clue???
  2. #2 Re: Clicking from front end when making right turns
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    I have the same thing going on with the 98 and replaced everything like you did. Did see somewhere where a person had this problem and they found it to be the starter. If you try it and it works let me know.
  3. #3 Re: Clicking from front end when making right turns
    Ocala, FL
    Might want to try another section.
  4. #4 Re: Clicking from front end when making right turns
    SE Level Member johnniep's Avatar
    nova scotia
    mine was making a clicking noise turning right,,,,,turned out to be the right front spring rubbing on the strut mount....might want to check it out....anyway i replaced the front struts and springs since i found it kinda low in the front
  5. #5 Re: Clicking from front end when making right turns
    Nov 2010
    Villa Ridge. Mo
    I replaced the starter and the noise is gone doesn't make any sents to me put it gone
  6. #6 Re: Clicking from front end when making right turns
    Pennsylvania
    Would have guessed the steering rack.
  7. #7 Re: Clicking from front end when making right turns
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  8. #8 Re: Clicking from front end when making right turns
    so this noise has been there for the last 2 years????? my god...lol
  1. GOD! He knows what turns you on!
    Last Post: 10-24-2010, 02:17 PM
  2. Clicking coming from front end 2004 Grand Prix
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-02-2010, 05:53 PM
  3. Heat/Air turns on by itself (DCC)
    By 2000GTGP in forum General Tech Discussion
    Last Post: 02-10-2010, 09:08 PM
  4. Airbag turns off & on
    By summersGT in forum General Tech Discussion
    Last Post: 10-15-2009, 12:18 PM
  5. What wire turns on amp?
    By rtb in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 08:13 PM
