Thread: 3.8 ltr. supercharged engine owner
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: 3.8 ltr. supercharged engine owner
    SE Level Member snookwheel's Avatar
    Florida
    Quote Originally Posted by ZR1Vette09 View Post
    very cool. Like matt said, some rockers would help give you a little more top end. And is it just me, or does the steering look like it could be tightened up some?
    The wide angle lens makes it look like the upcoming turns are less than what they are, so the steering wheel motion looks exaggerated compared to the turns. Here's a link of the exact same run shot from outside the car, you can see the turns are more severe than the wide angle in-car video makes them look. YouTube - Scott and Andy Bville 7-10.wmv
    Lock to Lock is two turns. I could put in a steering quickener, but we use it on the street quite a bit and that might make it a little touchy for normal road use. The weight to HP ratio is 5.5/1, I seem to run out of talent before I run out of speed so I probably won't be doing too much modding for more HP right away. When I start tracking the car vs. Solo events, the modding will probably start to happen!
    I stayed up way too late reading the tech forums! Lots of great info here.
  2. #22 Re: 3.8 ltr. supercharged engine owner
    Topeka, KS
    Wow that is like a go cart on Steroids! I bet that's fun as hell to drive!
  3. #23 Re: 3.8 ltr. supercharged engine owner
    now thats a nice ride. any plans on big motor mods like a cam to really wake that bad boy up?
    question: how loud and obnoxious is the exhaust being that these motors sound like trash?
  4. #24 Re: 3.8 ltr. supercharged engine owner
    MO
    Quote Originally Posted by snookwheel View Post
    I see. Well it's unanimous on these boards that the 3800 doesn't have alot of top end pull, maybe you'll find it'll help you be able to pull hard in high rpm's as well as low.
    <brandonl2000> LMAO D!!
  5. #25 Re: 3.8 ltr. supercharged engine owner
    Florida
    It is pretty loud if you put your foot in it. I have some baffles in the pipes, so it isn't too bad. No doubt it is ticket material if you floor it next to a cop. It does not have that great V8 AC cobra sound. Man, I like that big V8 sound.
    A few of you have mentioned a drop off at top end. I have not seen that at all. It pulls HARD to 6K+. I didn't put this engine together. It was torn down and rebuilt by the original owner before getting dropped into the Stalker.
    I just emailed the guy who put it together and asked if he modded the rocker/springs when he reassembled it. Hope to hear back soon. I have pushed it over 6K rpm and did not hear or feel any valve float, so maybe he did.
    Is there anything that identifys rockers / springs as 'something other than stock' looking through the oil fill cap? I would take the valve covers off, but we run next weekend and I won't be able to pick up fresh gaskets / have time to do it until the weekend. Guess I should move that question to tech help before moving down that path too far.
    I really appreciate the advice here. Great info. Scott
    Last edited by snookwheel; 08-02-2010 at 06:38 PM. Reason: pathetic typing ability
  6. #26 Re: 3.8 ltr. supercharged engine owner
    MA
    I want one lol
    SMGPFC Member #9
  7. #27 Re: 3.8 ltr. supercharged engine owner
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    Sweet
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  8. #28 Re: 3.8 ltr. supercharged engine owner
    Florida
    Heard back from the original owner. Springs and rockers are stock. Oh well, gives me a target to read up on.
  9. #29 Re: 3.8 ltr. supercharged engine owner
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    any modification to make that t5 trans work i wonder.
    <MiZzBeCcA>its not rape if you yell suprise
  10. #30 Re: 3.8 ltr. supercharged engine owner
    Florida
    The T5 is stock. The kit comes with a modified bell housing.
  1. 3.8l supercharged engine
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2010, 12:46 PM
  2. Engine issue 2006 gp supercharged
    By CoastGuard in forum General Tech Discussion
    Last Post: 11-07-2009, 11:46 AM
  3. LS9 Corevette Engine, Supercharged
    Last Post: 01-03-2008, 02:28 PM
