Thread: I smell coolant but can't find a leak 01 GP GTP
Results 1 to 6 of 6
  1. #1 I smell coolant but can't find a leak 01 GP GTP
    Feb 2010
    Ridge Manor, FL
    I don't get to drive my 2001 Grand Prix GTP very often, it mostly sits in the garage and is driven on the weekends. Well the other day I pulled it out and headed into town (it was a cold day) I stopped to get fuel and was smoking a little from under the hood. I popped the hood to take a look and could find a leak. It smells like radiator fluid but I can't find a leak. Has anyone had this problem???? I topped of my radiator fluid (which wasn't really low) the overflow tank was low. Could this be the dreaded intake gasket problem I've been reading about???
    Thanks for any input, I love my GTP and want it running perfect again.
  2. #2 Re: I smell coolant but can't find a leak 01 GP GTP
    Jul 2008
    sumter,south carolina
    more than likely lower intake manifold... look around valve covers and supercharger area and see if its puddling up around injectors or nooks and crannys of supercharger
    02 GTP with mods 05 GP for DD
  3. #3 Re: I smell coolant but can't find a leak 01 GP GTP
    Largo, Florida, United States
    check the coolant elbow under the supercharger
    mine sprang a leak there elbow cost 12$ from the dealer
    install it yourself.
    they overcharge you
  4. #4 Re: I smell coolant but can't find a leak 01 GP GTP
    Feb 2010
    Ridge Manor, FL
    I see a little fluid build up around the supercharger. I went down I got the intake gasket set. looks like thats going to be my weekend project, might as well do the elbows while I've got the hole thing apart. Thanks guys
  5. #5 Re: I smell coolant but can't find a leak 01 GP GTP
    GTP Level Member SuperSport's Avatar
    Michigan
    Hopefully you got the aluminum LIM gaskets. If you got the plastic ones, just don't use Dexcool, as that is whats eating the original gaskets in the first place.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  6. #6 Re: I smell coolant but can't find a leak 01 GP GTP
    Feb 2010
    Ridge Manor, FL
    I got the plastic ones, but I was planning on changing from the dexcool any ways. thanks
  1. Coolant smell in car
    By thewaitinggame in forum General Tech Discussion
    Last Post: 12-13-2009, 04:21 PM
  2. coolant smell
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 12:46 PM
  3. coolant leak
    By cheesewhiz in forum General Tech Discussion
    Last Post: 10-22-2009, 01:11 PM
  4. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
