Thread: New cuz my gf bought a 97 GT with loads of problems
Results 1 to 4 of 4
Threaded View
  1. #1 New cuz my gf bought a 97 GT with loads of problems
    Nov 2009
    Sun Prairie, WI
    Hi, I'm looking for a bit of help here, my girlfriend bought a 97 GT for $900, and it's in pretty good shape other than a few maintenance issues. So far this weekend I replaced both front wheel bearings (one howled bad), both rear struts (broken spring on driver's side, thought the clunking was from a bad mount but problem solved), taillights (cracked and full of water, plus half the bulbs were burnt out), headlights (one was duct taped on and both were about as dull as my beater Neon's), driver's mirror (missing lol), and now I'm stuck on this blower motor issue. Seems to be a common problem from Google but haven't seen any concrete answers. Symptoms:
    Blower works great on high, doesn't work at all on 1-4. Figured it was the resistor block, so I replaced it (that thing sucks to get to, luckily I just plugged new one in first to see if it fixed it, it didn't). Also noticed this since I need new lights in the garage, the DRL's turn off on 1-4, but stay on otherwise. Also noticed the rear defrost doesn't always come on, the relay in glovebox will click, and light will flash but then back off. Occasionally it'll work. When I set to 1-4, something under the dash by your left foot clicks, is that a BCM? When I unplug resistor block but leave blower relay plugged in, most stuff seems to work although the blower motor obviously doesn't.
    I've seen several questions about this and people keep mentioning ignition switch (how much is that thing?) and also some "ignition wire". I tried looking at this crappy manual I got at O'reilly's that doesn't have any damn wiring diagrams in it other than for under the hood, so I can't seem to figure out where everything goes. Gonna search on here to see if I can figure this out.
    Oh yeah, checked all the fuses too.
  1. Just bought it, and already problems =[
    By mr2stig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2009, 12:05 PM
  2. the one i bought
    By chad27 in forum Off Topic Discussion
    Last Post: 05-13-2009, 11:56 PM
  3. So I Bought Some =]
    Last Post: 01-26-2009, 11:13 PM
  4. highest G loads
    By Panther427 in forum General Tech Discussion
    Last Post: 01-01-2009, 10:08 PM
