Thread: 98 gtp lose power
Results 1 to 9 of 9
  1. #1 98 gtp lose power
    Nov 2009
    Missouri
    Hello all
    I have 98 gtp. Driving down road car dies but radio still works. Try to restart car starts sputters then dies hard. It is not fuel pump or fuel resistor or any fuses no vacuum leak. Think maybe a sensor like maf but not sure how to know if maf is bad. Also think could be ignition control module but do not know how to check that either. PLEASE HELP!!!! I have been w/o vehicle for 2 weeks
  2. #2 Re: 98 gtp lose power
    Troy OH
    sounds like MAF, same kinda thing happened to me on my way home from school like 4 days ago, the car just never died. if it is, you should have a service engine soon light on, just find someone who can read the code. mass air flow is P0102. also, you'll get a lot more help if you post in the tech tips section or some of the engine descussion further down the page
  3. #3 Re: 98 gtp lose power
    Nov 2009
    Missouri
    no service engine light is on but thanks for the info
  4. #4 Re: 98 gtp lose power
    SE Level Member 98bullit's Avatar
    Nov 2009
    Lawton
    check all your battery terminals and connections, ive had that happen to my camaro, all it was was the positive terminal that came off the battery was loose
  5. #5 Re: 98 gtp lose power
    SE Level Member Purple Plazma's Avatar
    Nov 2009
    Trevose,PA. (near Philly)
    I had an Olds Cutlass Ciera that did the same thing. Tested it by tapping on the sensor with the end of a screwdriver when the car was running to see if the car would shut down.
  6. #6 Re: 98 gtp lose power
    Nov 2009
    Lawton
    its barely connected enough to power the radio, but as soon as you crank it everythng dies
  7. #7 Re: 98 gtp lose power
    Nov 2009
    Maybe a good idea to replace the fuel filter too.
  8. #8 Re: 98 gtp lose power
    Guam
    Quote Originally Posted by troubled View Post
    Hello all
    How do you know it is not the fuel pump? It could be a clogged fuel filter, a bad fuel pressure regulatror. These things alone do not give codes. A bad MAF, or lose hose going to it, would probably do it as soon as it starts, it would, or could give a code too.
    Of course the radio will still work, you did not lose electrical power.
    The issue could also be a bad ignition module or a bad ECM.
    Without a code or light, it will be hard to diagnose over the internet.
    Start by taking the MAF out and cleaning it. You can buy the cleaner from most local auto stores.
  9. #9 Re: 98 gtp lose power
    Jul 2008
    sumter,south carolina
    did u notice the rpm's dropping to zero while the car was running?
    02 GTP with mods 05 GP for DD
  1. starting to lose my mind
    By 350D50 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 08:53 AM
