Thread: What kind of gains or how much horespower to see out of these up and coming engine
Results 1 to 14 of 14
  1. #1 What kind of gains or how much horespower to see out of these up and coming engine
    Banned
    Milwaukee
    Hello, first off i just bought this 2001, grand prix gt in febuary of this year nice little car stock 200hp, but i have been doing some research, and this is what kind of engine mods and all around mods i have came up with, but my question is how much power/ horespower to supect? Ok, Wizaired cold air induction, ZZP 1.0 PCM, Cat back exhaust SLP, ZZp 10.3mm spark plugs, Msd igition coils, Throttle body high velocity, Hv3 insert kit, hIGH ratio rocker, 180t-stat,colder spark plugs, Zzp poly motor mounts, THROTTLE BODY HEAT SHIELD TO REDUCE KR, WATER PUMP UNDERDRIVE PULEY, (Gmpp sway bars handling etc)
  2. #2 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Jersey
    you might want to add to the list plog and downpipe combo, if you plan on staying N/A. I don't really think you need a larger bore throttle body yet. Imo t/b heat shield, msd coils, and underdrive pulley are simply a waste of money, instead think about getting an Intense or trans-go shift kit.
    Before I had a similar mod list but, i didn't have a cai, rockers or hv3 and i ran a whopping 15.3 @ 88mph (1/4 mile)
    Im not sure what you would put down on a dyno but id guess 190-200 whp, less if its a mustang dyno.
    p.s- if you like your motor, you won't buy a zzp pcm. Get an Intense or overkill one
    16' wrx sti- stock
  3. #3 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Jersey
    BTW this is posted in the wrong section.
    16' wrx sti- stock
  4. #4 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Banned
    Milwaukee
    thanks for tha info, but whats wrong with zzp 1-o pcm
  5. #5 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Ohio
    ^ they are known to not be right an mess things up
    00 GTP demodded and forsale
  6. #6 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Banned
    Milwaukee
    So dont go with zzp go with intense or overkill
  7. #7 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Ohio
    ^ exactly or a custom tune which is overall your best option
  8. #8 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Banned
    Milwaukee
    ok thanks for tha help so should i buy a cai first before i buy tha pcm?
  9. #9 Re: What kind of gains or how much horespower to see out of these up and coming engin
    SE Level Member FRESCOLIO's Avatar
    CHICAGO
    Change the cam.
  10. #10 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Banned
    Milwaukee
    yea but should i get a cold air thing or a pcm?
  11. #11 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    with my setup i have a dp plog hv3 and 180 t stat and ran a 15.4 with stock pcm but if i had to chose id do pcm first and just put a cone filter on the intake tube thats all i did and it works good i just take out my driver side headlight at the track to get cold air hitting it but ya all the heat sheild ported tb are useless on a stock car id save that till u are more modded with all the stuff i have plus rockers and pcm then id do ported tb and as for msd coils its the same as oem ur just paying for a name if u want them it would be just cosmetic they perform same as stock
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  12. #12 Re: What kind of gains or how much horespower to see out of these up and coming engin
  13. #13 Re: What kind of gains or how much horespower to see out of these up and coming engin
    Minnesota
    Quote Originally Posted by cellurbb View Post
    a cold air thing.. read blues thread its got all sorts of goods in it
  14. #14 Re: What kind of gains or how much horespower to see out of these up and coming engin
    ya i agree read blues sticky
    sold 97 GTP stock
  1. N* gains
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 09:50 AM
  2. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
  3. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
  4. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  5. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
