Thread: new to forum with svs light problem
Results 1 to 5 of 5
  1. #1 new to forum with svs light problem
    ms
    trying to find answer to my dilemma. was riding down the road and service vehicle soon light came on along with change oil. Changed oil and reset oil light. Now I start car and sometimes everything is fine, sometimes no daytime running lights. (been going on for a week). SVS light comes on and now have no DRL's, no power to windows, and no power to AC system. I will be riding down the road and all of a sudden everything works. Turn car off and when restart, same problem, no lights, window power, or blower power. Also sometimes when start car, no dash panel lights come on for a few seconds, then they appear and go off but service vehicle soon light stays on. Took it to autozone and no codes show up. Any suggestions or help would be very much appreciated.
  2. #2 Re: new to forum with svs light problem
    Becca Boo MizzBecca's Avatar
    Michigan
    Check alternator. Also if you have any aftermarket stereo, speakers, or subs hooked up make sure none of the wires have any coating rubbed off, that can cause a short through out the car.
    I drive a POS
  3. #3 Re: new to forum with svs light problem
    GT Level Member JessinaterGTP's Avatar
    Elmira ny
    It just sounds like a short somewhere. Don't make the wrong mistake and fix everything cause your going to put yourself in a big money problem. Best bet is to take it to a small car shop and ask them first. More than likely they wont rip you a new one.
  4. #4 Re: new to forum with svs light problem
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    ^ x2 on the short issue, and unfortunately; electrical system gremlins are not easy to find. I would have a shop take a close look inside the steering column (you could do this yourself, too) and make certain that there aren't any wires that have been rubbed bare or crimped from the tilting of the steering wheel. Also - take a look at your fuse box under the hood - make sure that the nut at the top is tight and not corroded. Also check your battery connections for corrosion/tightness.
    HTH, best of luck
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  5. #5 Re: new to forum with svs light problem
    ms
    this is for anyone else that has had this problem. You won't believe what this turned out to be. After much debate of what to do, (have dealer put on computer and spend $85.00 or take a chance and start replacing things). I was driving down the road, hit a pothole and lost all power. Luckily car restarted and made it home. Did a lot of research of what powers all the items that were lost, decided to replace just the ignition switch and keeping the older lock assembly. Also kept the battery hooked up while replacing the part. It was a bear to get to, especially if you have big hands. Got it back together, turned the switch, and voila!!! Car starts right up and power to everything. Been driving it for four days now and no problems. Hope this helps anyone that has run into this situation and thanks to those that replied to try help out. (I swear this car is possessed)
  1. interior light problem
    By gtman98 in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2010, 09:47 PM
  2. Problem with acessing forum
    By chrizzle17 in forum Forum Bugs/Suggestions
    Last Post: 10-02-2009, 01:39 AM
  3. problem with engine light?
    By CheeWee in forum General Tech Discussion
    Last Post: 07-07-2009, 01:29 AM
  4. Hello, new to this forum and having a problem with my GTP
    By PSYCHO in forum Introductions/Noob Questions
    Last Post: 05-23-2009, 11:19 PM
  5. light problem!!!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 04-21-2008, 12:11 PM
