Thread: Engine Dies?
Results 1 to 4 of 4
  1. #1 Engine Dies?
    Jul 2022
    Tuksa
    I have a 2004 Pontiac Grand Prix 3.8 six cyl
    190,000 miles
    Thr problemis it will die, sometimes? It will restart vey easy, it does not stutter or misfire, just dies. It does this after driving maybe 3 miles. It will always restart,very easy. any sugs
  2. #2 Re: Engine Dies?
    St. Louis
    Keep an eye on the tach. If it drops to zero while its still running/right before it dies then I would say crankshaft position sensor. And no, they do not usually throw a CEL.
    Other than that could be a failing ignition control module (the metal plate that your coil packs mount onto).
  3. #3 Re: Engine Dies?
    Apr 2014
    commerce twp,mi
    went through similar with my '08 except it would die randomly when coasting to a stop or at a stop. little more to the story ( where i ended up with crank but no start) but replaced a cracked coil and ICM and problem disappeared.
    08 grand prix NA3800
  4. #4 Re: Engine Dies?
    Apr 2014
    commerce twp,mi
    forgot to mention- scan for codes. cylinder misfire would tell me one of the 2 mentioned above
  1. 3.8 engine dies when it warms up
    By Jason97GrandprixGT in forum General Grand Prix Discussion
    Last Post: 01-03-2016, 08:00 PM
  2. Engine dies while driving?
    By AZGPrix in forum Introductions/Noob Questions
    Last Post: 03-26-2015, 09:15 PM
  3. Engine dies
    By 45Longcolt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2013, 11:07 PM
  4. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  5. Engine dies!?
    By Jaybird in forum General Tech Discussion
    Last Post: 06-30-2010, 07:13 PM
