Test the bulb to make sure both filaments work. "Brand new" means nothing.
Test the socket that is the issue. If it isn't getting power, then you need to work your way back to find where the power is being lost. If the other connected bulbs are working, then I'd suspect a bad "brand new bulb", or a bad light socket.
