Thread: 97 gtp
Results 1 to 15 of 15
  1. #1 97 gtp
    Aug 2017
    illinois
    i need help with a fuel issue
  2. #2 Re: 97 gtp
    Aug 2017
    illinois
    i replaced the fuel pump and checked the ballast resistor, ( fuel pump resistor) by bypassing the relay, i go to turn key , new pump,( ive tried 3 other new ones btw) and it primes but no gas will spray, i even hotwired the pump and still, will keep running and wont spray any fuel. checked for codes, no codes come up
  3. #3 Re: 97 gtp
    clogged filter?
    you can check to see if the injectors are getting power too, test light in the plug of one while someone tuns the key and then cranks it while you test. they only flash for a few seconds to prime the engine, so it will be short. but if they flash they should be working.
    if they dont flash, start checking the wire harness for damage. near the pcm where the harness runs past the ac lines in one place they rub through.
  4. #4 Re: 97 gtp
    Oct 2014
    portland oregon
    Check pressure at the regulator as well. I have a 97 and it get joy by pissing me off
  5. #5 Re: 97 gtp
    Aug 2017
    illinois
    my filter i changed with the pump, ill check tomorrow for the injectors, but shouldnt the fuel punp itself be spraying fuel out of the fuel nossel regaurdless?
  6. #6 Re: 97 gtp
    Oct 2014
    portland oregon
    By nozzle do you mean the valve on the fuel rail? If yes when cranking fuel should squirt out of it
  7. #7 Re: 97 gtp
    Aug 2017
    illinois
    when i changed fuel filter i released all the pressure, amd the the fuel nozzle that is on the fuel pump itself, it has the fuel nozzel the nozzle in the middle and the return nozzel, when the pump activates no gas will go throught the pump sending unit, ive tried manually priming it , bringing the gas to the top of the pump, expecting to turn the keyand the pump to at least drizzle some out , but i cant get that either
  8. #8 Re: 97 gtp
    I break stuff selliott's Avatar
    Kansas City
    I don't remember does it have a check valve?
  9. #9 Re: 97 gtp
    Aug 2017
    illinois
    i dont know where the check valve would be
  10. #10 Re: 97 gtp
    it has the fuel nozzel the nozzle in the middle and the return nozzel, no idea where this nozzle is lol
  11. #11 Re: 97 gtp
    Aug 2017
    illinois
    the pieces of the fuel pump, ill send a pic later
  12. #12 Re: 97 gtp
    Aug 2017
    illinois
    its not letting me send a pic of the fuel pump off my phone
  13. #13 Re: 97 gtp
    tap talk seems to let you phone guys post pics, or use a hosting site and drop a link to the pic.
  14. #14 Re: 97 gtp
    Aug 2017
    illinois
    but look up a picture of a fuel pump, the top of the pump is what i cant get to send fuel , from the sending unit , and the pump is brand new and isnt faulty,
  15. #15 Re: 97 gtp
    Aug 2017
    illinois
