Im aboit to do the trasmission overhaul. I wanna add 1 quart of either lucas transmission fluid conditioner or lucas transmission fix. What is better or shoukd not even worry about it?![]()
If it is a rebuilt transmission, I don't see the point as there shouldn't be any excess slip if the trans was rebuilt correctly. I do remember TripleEdge Performance transmission having a little Catepilar (I think it was) trans fluid mixed into the Dex for high Horsepower applications. I think the idea was that the thicker fluid would stick better to the clutch packs when they were spinning trying to hold Torque levels they weren't really designed for...
Not a rebuild, a overhaul. ie. Transgo shift kit, filter, gasket, dexron 6 fluid, and a trans cooler. It is a new car to me, and i wanna treat my Ocean to something nice.
Sent from my SM-G930P using Tapatalk
Don't use it then. Fresh fluid and a new filter is perfectly fine.
Ok, thank you
