Thread: Lucas Transmission question
Results 1 to 8 of 8
  1. #1 Lucas Transmission question
    Jun 2017
    Indianapolis, IN
    Im aboit to do the trasmission overhaul. I wanna add 1 quart of either lucas transmission fluid conditioner or lucas transmission fix. What is better or shoukd not even worry about it?
  2. #2 Re: Lucas Transmission question
    GTP Level Member buickman104's Avatar
    NYC
    If it is a rebuilt transmission, I don't see the point as there shouldn't be any excess slip if the trans was rebuilt correctly. I do remember TripleEdge Performance transmission having a little Catepilar (I think it was) trans fluid mixed into the Dex for high Horsepower applications. I think the idea was that the thicker fluid would stick better to the clutch packs when they were spinning trying to hold Torque levels they weren't really designed for...
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Lucas Transmission question
    Jun 2017
    Indianapolis, IN
    Not a rebuild, a overhaul. ie. Transgo shift kit, filter, gasket, dexron 6 fluid, and a trans cooler. It is a new car to me, and i wanna treat my Ocean to something nice.
    Sent from my SM-G930P using Tapatalk
  4. #4 Re: Lucas Transmission question
    May 2016
    Lincoln, Nebr
    Don't use it then. Fresh fluid and a new filter is perfectly fine.
  5. #5 Re: Lucas Transmission question
    Jun 2017
    Indianapolis, IN
    Quote Originally Posted by JohnRider View Post
    Alright, thank you. How many quarts does the tranny take? Between 6-7?
  6. #6 Re: Lucas Transmission question
    You're adding a cooler and removing parts of the transmission that hold fluid to do the shift kit, you'll need atleast 8-9 quarts.
  7. #7 Re: Lucas Transmission question
    Jun 2017
    Indianapolis, IN
    Ok, thank you
  8. #8 Re: Lucas Transmission question
    Jun 2017
    Indianapolis, IN
    Tru cooler 4454, any good? On a budget
  1. new guy, big transmission question
    By grandprix92 in forum Introductions/Noob Questions
    Last Post: 01-18-2016, 01:22 PM
  2. Lucas Transmission Fix Question
    By SubwayGuy in forum General Grand Prix Discussion
    Last Post: 04-21-2015, 07:48 AM
  3. Transmission question
    By Tom0247 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-23-2013, 06:30 PM
  4. transmission question
    By rmplow in forum General Tech Discussion
    Last Post: 12-26-2010, 07:51 PM
  5. question about my transmission
    By 01prixse in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-27-2009, 05:00 AM
