Thread: Rear Strut replacement help
Results 1 to 12 of 12
  1. #1 Rear Strut replacement help
    SE Level Member Felix's Avatar
    Jul 2016
    Just wondering what are all the tools/torque specifications, I would need to replace both rear struts on a 02 grand prix gtp. As well as what size was the socket for the hub? Forgot which one it was. Two struts gave out on me this morning while I was on the highway, buckled and spun me out, only thing damaged was the rear passenger rim, left wheel hub assembly and the strut. Luckily, didn't hit anything.
    Plis Halp
    02 GP GTP "Delphene" in Redfire Metallic
    CURRENT - E85, AEM E85 Pump, 60# SD60, 3.4 pulley, ZZP DP, K&N CAI.
    NEAR FUTURE - 3.2/3.0 pulley, TEP HPS3 TRANS, ZZP 3in catback exhaust.
  2. #2 Re: Rear Strut replacement help
    Top nuts are 13 or 14mm, knuckle bolts are 21mm if I remember right. Big hammer to smack the bolts through the knuckle.
    Torque spec is german, just get them good n' tight.
    Hopefully the rear strut tower are in good shape.
  3. #3 Re: Rear Strut replacement help
    Jul 2016
    Thats what im hoping on. At a buddy's shop atm. About a grand to get the struts replaced, new rim, alignment and the wheel hub. About $850 once I get this timken one off and replaced under warranty.
    Plis Halp
  4. #4 Re: Rear Strut replacement help
    Jeezus, that crazy talk for getting that kinda work done.
    New rear struts are only like 100-130 each fully assmebled from like a napa. Labor is free if you do it yourself, they are easy. 70-90 for an alignment and a free bearing if it's under warranty.
    This could totally be done for less than $400 if you did the work.
  5. #5 Re: Rear Strut replacement help
    i just did all 4 struts not to long ago. rears were easy. got ebay struts, never rode better, also removed the ass sag.
  6. #6 Re: Rear Strut replacement help
    Nov 2012
    Madison
    I would like to hear why this happened.
  7. #7 Re: Rear Strut replacement help
    Nov 2013
    pittsfield ma. 01201
    Just did mine used quick struts not that hard to do
  8. #8 Re: Rear Strut replacement help
    GTP Level Member
    Oct 2014
    Like these Scotty?
    They are 1/2 the price of Monroe.
  9. #9 Re: Rear Strut replacement help
    just like that. ^^^^^
    they sell pairs and all 4. all 4 works out a bit cheaper if you need all 4. let me tell ya, you likely need all 4 lol i thought mine were "OK", i thought way wrong after changing them.
    i also picked up a set of front and rear camber bolts, wish i had bought them before i installed the struts, now ill be popping out a bolt on all 4 corners before i go for an alignment.
  10. #10 Re: Rear Strut replacement help
    GTP Level Member
    Oct 2014
    Thanks. I have 190K on my 08. Probably time and 60 bucks a unit is cheap.
  11. #11 Re: Rear Strut replacement help
    Jul 2016
    Guys opinion on Ac Delcos? Isn't that like GM Factory parts? Each strut is $118, or some Moogs for $80.
    Plis Halp
  12. #12 Re: Rear Strut replacement help
    delco is what would have come new from the factory.
    in the end, anything new is better then old worn out stuff.
  1. How to for strut replacement
    By GTPNovak in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2016, 10:00 AM
  2. 04 comp-g strut replacement
    By phat pat in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2012, 12:56 AM
  3. Rear Strut replacement 04+?
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2011, 04:31 PM
  4. Strut replacement
    By chumley in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 08:59 PM
  5. Need help, strut replacement
    By rodie1200 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 08:36 PM
