Thread: 04 comp-g strut replacement
Results 1 to 3 of 3
  1. #1 04 comp-g strut replacement
    Jun 2010
    Spokane WA
    hey all, Im putting togeather a parts list for my comp-g, needing to replace all four struts and mounts.
    Im gona reuse my stock springs for now, I read the thread about the 04/05 gp haveing a different strut/sway bar setup then everything else. Im also interested in the kyb excel-G for the FE4 monty (http://www.grandprixforums.net/kyb-e...ech-45867.html) as im useing my stock springs that will have sank alittle, this should work great. but will they work? or will have have to change my A arms?
  2. #2 Re: 04 comp-g strut replacement
    Jun 2010
    Spokane WA
    anyone? i just don't want to order monroe struts. i also want to know what if i can change just the LCA and keep the stock sway bar, or will I need to replace the sway bar also. maybe with stock 06+ or what not?
  3. #3 Re: 04 comp-g strut replacement
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    Stick with the CompG Struts, IMO. Part numbers 88955411 and 88955413. I think they might be making GR-2s now for the 04/05 that don't require new LCAs, but I prefer the CompG struts over them. CompG struts are stiffer than the base model. I paired mine with some DNA springs and couldn't be happier with the handling and ride, as well as price.
    Be careful about the rear top mounts, a lot of companies make a universal replacement that is a pile of crap, when I changed mine I got some and ended up keeping my stock rear mounts. They don't get any weather/moisture on top since they are in the trunk and are probably fine anyway, no bearings to wear like the front.
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  1. Comp G strut swap
    By Compg4me in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2012, 07:58 PM
  2. Front Strut Replacement
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2012, 06:50 AM
  3. Rear Strut replacement 04+?
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2011, 04:31 PM
  4. Strut replacement
    By chumley in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 08:59 PM
  5. Need help, strut replacement
    By rodie1200 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 08:36 PM
