Thread: Just registered here.May have a lot of questions.
Results 1 to 4 of 4
  1. #1 Just registered here.May have a lot of questions.
    Jun 2017
    Trevose, PA
    First off, will a Gen II 3800 GTP supercharger work with a Gen III engine? I know the last generation Grand Prix GTPs have 20 more horsepower (260 vs 240) but is that hp increase due to a different supercharger?
    I'm considering a deal on a 2004 GTP but the supercharger needs a rebuild. There's a nice supercharger removed from a '99 Gen II GTP at a local salvage yard. The counter guy said the superchargers will bolt up to any Gen II or Gen III 3800 GTP.
    Any help is appreciated.
    Steve
  2. #2 Re: Just registered here.May have a lot of questions.
    Can it bolt up, yeah but it's not that simple.
    Series 3 motors have a different LIM, different PCV system and different throttle body. You'd need a series 2 LIM, throttle body adapater plate and other smaller things.
    Why does the 04 car need a S/C rebuild? Are they sure it's not just the coupler than went bad and it sounds like rocks in a bucket at idle.
  3. #3 Re: Just registered here.May have a lot of questions.
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Even if it really does have the bearings out, those probably cost less than a GenIII supercharger. Disassembly isn't simple. Also you'll need a press big enough of find a shop that'll press them out for you. The needle bearings can be a bear tho.
    Honestly, I wouldn't go back to a GenIII just because Eaton really knows wtf they're doing and the GenV is a drastic improvement.
  4. #4 Re: Just registered here.May have a lot of questions.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Sseilmnop rebuilds snouts for a very reasonable price deffinately cheaper then buying a gen 3 and lim and throttle body adapter while managing to lose horsepower and reliability. First check the coupler its a 20$ part and 90% of the time that is the part that's broken. If it does actually need bearings replaced then hit up Sseilmnop and he will hook you up and then you have a supercharger that has brand new spanking seals and bearings that you know is going to last a long time.
    Sent from my LG-H918 using Tapatalk
  1. finally registered, but looking to sell 97 GTP
    By taplai0 in forum Introductions/Noob Questions
    Last Post: 07-29-2016, 08:58 PM
  2. Can't get my DHP registered
    By jdmgtp in forum PCM Tuning
    Last Post: 09-03-2014, 05:37 AM
  3. Just Registered ! From INdiana
    By Logan in forum Introductions/Noob Questions
    Last Post: 09-10-2010, 11:45 AM
  4. Finally registered.. red gtp
    By Perry125 in forum Introductions/Noob Questions
    Last Post: 08-22-2009, 09:58 AM
  5. finally registered....
    By kfog in forum Introductions/Noob Questions
    Last Post: 06-20-2009, 10:44 AM
