Thread: Rim Size Question
Results 1 to 6 of 6
  1. #1 Rim Size Question
    SE Level Member Felix's Avatar
    Jul 2016
    Hey guys, I plan on buying some 20 inch rims from a friend, was going to buy some tires but 4 set of new 20 inch rims as well as a tire set for $200 seemed like a deal for me, just wondering if I'll run into any problems with an 02 Grand Prix GTP running this rim size. Not exactly sure what the tire size is though.
    Plis Halp
    02 GP GTP "Delphene" in Redfire Metallic
    CURRENT - E85, AEM E85 Pump, 60# SD60, 3.4 pulley, ZZP DP, K&N CAI.
    NEAR FUTURE - 3.2/3.0 pulley, TEP HPS3 TRANS, ZZP 3in catback exhaust.
  2. #2 Re: Rim Size Question
    Tire size and offset will need to be known.
    Too large of tire and a low offset rim will rub the fenders. Then on the other hand a rim with like a +50 offset might rub the strut with wide wheels too.
  3. #3 Re: Rim Size Question
    St. Louis
    What is the offset, backspacing, hub bore and bolt pattern is on these rims? 20's can fit if done right.
  4. #4 Re: Rim Size Question
    Jul 2016
    Wont know till tomorrow, will update you guys on the info.
    EDIT: Believe its 245/35r20
    Plis Halp
  5. #5 Re: Rim Size Question
    Nov 2012
    Madison
    Quote Originally Posted by Felix View Post
    Well thats a good start. Correct tire size on twentys is always a good thing.
    If 20s rock your world go for it.
  6. #6 Re: Rim Size Question
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    You'll need to know the offset at minimum. Might have to roll your fenders, I dunno. Hopefully, they don't hit any part of the strut.
  1. tire size question
    By SCoRPiuS7 in forum Tires & Wheels
    Last Post: 03-31-2013, 07:34 PM
  2. Hid size question
    By mk frilla in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2013, 03:08 PM
  3. question about rim size
    By rambo33 in forum Visual/Body Modifications
    Last Post: 12-22-2009, 12:05 PM
  4. Tire size question
    By Damojo2003 in forum Tires & Wheels
    Last Post: 04-30-2009, 08:19 AM
  5. Sig size question
    By fatride99 in forum Site/Club News
    Last Post: 01-27-2008, 09:17 PM
