Thread: 02 coolant temperature sensor
Results 1 to 9 of 9
  1. #1 02 coolant temperature sensor
    Mar 2017
    Missouri
    I just replaced the temperature sensor and the temperature guage is reading hot, and way over at that, but that's when it was cold also and when the engine is off. I took it to o'reilly to check it and it's still coding. Now, the old one was only in about half way, my friend threaded the new in all the way, could this be the issue or could it be shorted out or a bad sensor like o'reilly's say. and if it's a short, how do I fix that? Thanks in advance.
  2. #2 Re: 02 coolant temperature sensor
    May 2008
    Schuyler, NE
    Are you sure the wire is plugged in? If you have a bad connection, the temp gauge will read hot.
  3. #3 Re: 02 coolant temperature sensor
    St. Louis
    Is it a delco one? The aftermarket ones have been known to be bad out of the box, sometimes 2 or 3 in a row. Went through this last year. Ended up going to GM to get one.
  4. #4 Re: 02 coolant temperature sensor
    Mar 2017
    Missouri
    Yeah it's plugged in fully and no its a master pro.
  5. #5 Re: 02 coolant temperature sensor
    Mar 2017
    Missouri
    I saw something online that if I unplug it, start the engine and it goes cold it's the sensor. However, could it be that it's threaded in all the way and not half like the old one? I unplugged it and it went cold.
  6. #6 Re: 02 coolant temperature sensor
    SWPA
    If its reading hot when plugged in then it is likely a bad/grounded sensor.
  7. #7 Re: 02 coolant temperature sensor
    Mar 2017
    Missouri
    Bad sensor. Took it back to o'reilly and got a new one, works fine. However, when trying to put it on the gray plastic broke in half so I said screw it and taped the damn thing for now. Temp gauge is good. Thanks for everyone's help.
  8. #8 Re: 02 coolant temperature sensor
    GTP Level Member
    springfield IL
    i ended up getting a new plug/harness. solved my issue with it.
  9. #9 Re: 02 coolant temperature sensor
    Mar 2017
    Missouri
    Quote Originally Posted by tc300 View Post
    I noticed mine had a few small burn marks in the wires so I taped them too, no issues so far with that.
  1. Changing the coolant temperature sensor
    By Jeremy05GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2017, 10:39 AM
  2. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  3. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  4. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
