Thread: How to disable DRL
Results 1 to 10 of 10
  1. #1 How to disable DRL
    SE Level Member Felix's Avatar
    Jul 2016
    What would I need to do to disable daytime running lights?
  2. #2 Re: How to disable DRL
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    The only reason I went and got this is because I knew right where it was. Just saw it today looking for something else.
    http://www.grandprixforums.net/threa...-04-grand-prix
  3. #3 Re: How to disable DRL
    Jul 2016
    Thanks, hmm says it may work on older models, wonder if anyone has tried it on on an 02.
    EDIT: Oh nevermind, read the thread a bit more and one of the comments said for 97-03 cars to just "pull out the plug that goes into the heatsink behind driverside dash.".
  4. #4 Re: How to disable DRL
    May 2016
    MN
    Err.. thought it was a fuse on those. Been a long time, lol.
  5. #5 Re: How to disable DRL
    Aug 2016
    MN
    I disabled mine by pulling a fuse
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  6. #6 Re: How to disable DRL
    Jul 2016
    Do you remember which one from the fuse box? That will be a lot less work haha.
  7. #7 Re: How to disable DRL
    St. Louis
    Check your owners manual. Should be listed.
  8. #8 Re: How to disable DRL
    Jul 2016
    Dont have my manual, just went ahead and pulled out the plug from the driverside dash. No more DRL
  9. #9 Re: How to disable DRL
    May 2016
    MN
    I'm pretty sure if you look at the label on the back of the fuse door or on the block itself, it should say DRL right on the fuse.
  10. #10 Re: How to disable DRL
    Jul 2010
    Coquitlam,BC,Canada
    Depends on the year. Some '01+ cars you can't just pull the fuse.
    When I pull the fuse, the DRL diode buzzes. If I unplug the DRL diode and remove the fuse, the DRL's don't work, plus the "auto" on" function stops working also. So, I just have the DRL diode unplugged. If you don't want the "auto on" to work, you need to unplug the DRL control module. I have the headlight wire removed from the plug of the module, so just the park lights "auto on".
    Here are some visuals:
    http://chrisb.users.superford.org/Gr...tml#MAY27-2015
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. DoD disable...but why?
    By Altairus in forum 5.3L V8 (LS4)
    Last Post: 10-16-2019, 09:11 PM
  2. Disable DRL on 04+?
    By arlenok in forum General Tech Discussion
    Last Post: 05-02-2014, 06:36 PM
  3. DOD disable
    By gtx3800 in forum 5.3L V8 (LS4)
    Last Post: 06-21-2013, 01:12 PM
  4. DRL disable 04+
    By acidrayne280 in forum 04+ Specifics
    Last Post: 05-03-2012, 10:18 PM
  5. DRL disable
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 12-16-2008, 09:33 AM
