Thread: Hoping for a quick response HELP
Results 1 to 14 of 14
  1. #1 Hoping for a quick response HELP
    Jan 2017
    Sauk Rapids Minnesota
    Just went to turn my car around to load some stuff up and now the is stuck in the ignition. Any ideas or answers
    Sent from my SM-G920P using Tapatalk
  2. #2 Re: Hoping for a quick response HELP
    Buffalo
    Key is stuck? Is it all the way in park? Try pushing harder on the shifter
  3. #3 Re: Hoping for a quick response HELP
    Jan 2017
    Yeah I tried that once but I'll give it another whirl!
  4. #4 Re: Hoping for a quick response HELP
    will it fire back up if you try to start it? if so its not a dead battery.
    under the column is a round plug, pop it off and then push a pen or stick in the hole and you can turn the key back.
    most of the time this is caused by a busted wire to the shiftier in the console.
  5. #5 Re: Hoping for a quick response HELP
    Jan 2017
    It does start again and okay I will try that now. It also looks like I'm low on oil. Would that have any affect?
  6. #6 Re: Hoping for a quick response HELP
    Jan 2017
    I left the car idle for a few minutes and when I got the key to come out this time! I'll remember to check this in case it happens again. Thank you scottydoggs and crazyguy03
  7. #7 Re: Hoping for a quick response HELP
    heres the you tube how to repair it, this guy went and crimped new pins on, but you can patch it, ot lop it off and replace it with a jy plug.
  8. #8 Re: Hoping for a quick response HELP
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Low on oil?! How do you know? Did the oil light come on? If it did.... ohh nozzz.
    Get some oil in there quick. Don't drive it! Walk to the nearest gas station.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  9. #9 Re: Hoping for a quick response HELP
    Jan 2017
    Would it be the same case with my 08? Since the ignition isn't behind the wheel? Also yes the light came on. Luckily the gas station is right behind me!
  10. #10 Re: Hoping for a quick response HELP
    low oil wont do this, but find out why its low asap. the oil pressure senders like to blow out and you loose oil fast when they do go. leaves a puddle under the oil filer on the pass side.
  11. #11 Re: Hoping for a quick response HELP
    Jan 2017
    I'm not seeing any puddles so I believe it's just low. Also rookie here lol it seems as though my vehicle doesn't have a hood prop? Where can I pick one up?
  12. #12 Re: Hoping for a quick response HELP
    you dont have one. you have lifts that are shot if it wont stay open on its own.
  13. #13 Re: Hoping for a quick response HELP
    Jan 2017
    Well hell. Thanks for all the help!
  14. #14 Re: Hoping for a quick response HELP
    ebay. like 30 bucks and your set. same for the trunk if thats falling on your head too. and that hurts pretty bad lol
  1. Ignition switch install question. Quick response please!
    By TheInterloper in forum General Tech Discussion
    Last Post: 02-23-2013, 11:18 AM
  2. NEED RESPONSE QUICK! fuel pump fuse blowing, part throttle hesitation
    By usetaboost in forum General Tech Discussion
    Last Post: 01-02-2013, 08:46 AM
  3. Hoping I can get more life out of it...
    By Fahrenheit in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2012, 01:54 PM
  4. hoping to find help
    By zeke8226 in forum Introductions/Noob Questions
    Last Post: 01-31-2011, 04:25 AM
  5. Some problems that I am hoping someone has had
    By GTPOWER in forum General Tech Discussion
    Last Post: 07-21-2008, 11:16 PM
