Thread: 2000 Grand Prix "TEMP" light on dash when cold outside.
Results 1 to 4 of 4
DerrickCaldwell 2000 Grand Prix "TEMP" light... 01-04-2017, 04:49 PM
Explicit_Spade Re: 2000 Grand Prix "TEMP"... 01-05-2017, 12:41 AM
DerrickCaldwell Re: 2000 Grand Prix "TEMP"... 01-07-2017, 09:49 AM
Scottydoggs Re: 2000 Grand Prix "TEMP"... 01-07-2017, 09:58 AM
  1. #1 2000 Grand Prix "TEMP" light on dash when cold outside.
    Jan 2017
    Detroit, MI
    Hello All,
    3 months ago I purchased a 2000 Pontiac GP SE and am having trouble with starting it in cold weather. When its warm or mild out, it cranks up first try everytime, no issues. When it is cold out, dash shows "TEMP" light and does not crank or turnover just clicks once and when ignition is triggered. Has new battery and starter. Need help! I live in Michigan and need this car to run this winter!
  2. #2 Re: 2000 Grand Prix "TEMP" light on dash when cold outside.
    Omaha, NE
    What he said ^^^
    Cold Cranking Amps are key for winter starts. Make sure the battery cables are clean and tight.
  3. #3 Re: 2000 Grand Prix "TEMP" light on dash when cold outside.
    Jan 2017
    Detroit, MI
    Thanks for the insight guys, car started randomly yesterday at about 6pm est. it was about 11 degrees out. I drove it, then parked. Then drove it again at about 12am. Woke up to drive it this morning and no start. 8 degrees today. Battery connections look good and clean! Lights and radio and everything comes on, just wont turnover in cold for some reason...
  4. #4 Re: 2000 Grand Prix "TEMP" light on dash when cold outside.
    if the click you hear is in the dash and the cluster blacks out like normal when key is turned to crank, thats the starter. new/rebuilt parts have been found to be doa in the box.
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. "Trixie" 2000 Grand Prix GTP *Picture Heavy*
    By Alcatraz in forum Members Rides
    Last Post: 07-29-2013, 11:06 PM
  3. quick question... is this the "temp sensor" on 95' gtp (pic included)
    By Falcons33 in forum General Tech Discussion
    Last Post: 04-23-2013, 05:41 PM
  4. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
