Thread: Need Mechanic! Rear Hub Assembly
Results 1 to 4 of 4
  1. #1 Need Mechanic! Rear Hub Assembly
    Oct 2014
    Cle
    In Charlotte NC area, need right rear wheel assembly installed,contact me asap! Looking to pay
  2. #2 Re: Need Mechanic! Rear Hub Assembly
    SE Level Member Keko's Avatar
    Nov 2016
    California
    You'd have better luck looking up a mobile mechanic in your area on craigslist.
    [Daily] 2002 GTP 40th Ann - FSIC, dp+plog, 3.3", ported LIM, HAI, front+rear sway bars, poly mounts, zzp tune for now :/
    [Fun] 2012 mazdaspeed3 - dp, 3" intake, FMIC, HPFP, Custom tune, lots of other goodies
  3. #3 Re: Need Mechanic! Rear Hub Assembly
    May 2016
    Lincoln, Nebr
    Give it a try yourself and save that money, https://www.youtube.com/watch?v=Un81uD1XCrY&t=607s
  4. #4 Re: Need Mechanic! Rear Hub Assembly
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Agreed. It's really not hard to do. If you have a tool set it will be good experience.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. Rear Hub Assembly - How hard can it be?
    By jpgwinn24 in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2013, 10:13 AM
  2. can front brake assembly be put on rear??
    By exofis in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2011, 05:09 PM
  3. need help with rear hub assembly removal 97 gtp
    By tiedye in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2011, 12:27 PM
