Thread: What is this bolt?
Results 1 to 5 of 5
  1. #1 What is this bolt?
    Dec 2016
    Texas
    I have a 2000 Grand Prix 3.8L and I noticed my car has oil running down the passenger side of the engine and it appears to be trickling out of a threaded hole on the side of my engine. The hole is just below the lower intake gasket but above the water pump. I found the below picture online of the side of a 3.8L engine and there appears to be a bolt (marked with yellow arrow) but my car is missing this bolt and just has an empty hole. My question is what is this bolt? Does it go to anything inside the engine? Do I need a certain length or can I just pick up a short bolt at the hardware store that matches the threading to screw in a stop the oil that's trickling out?
    What is this bolt? Attached Images
  2. #2 Re: What is this bolt?
    looks like it does nothing you need to worry about.
  3. #3 Re: What is this bolt?
    hangover park IL
    its a through hole to the inside of the crankcase, oil mist/pcv vapor will exit it if no blocking bolt is installed.
    m10x1.5 thread, less than 15mm uhl/thread length. that hole is used on the older g/h body engine mounts that make it a pita to change the belts.
    each cylinder head also has a through hole near the injectors that is only used on certain models/mounts/accessories that provide the same leak path from the crankcase to the outside world.
    ~James~ Psychotic Gearhead
  4. #4 Re: What is this bolt?
    Antioch, IL
    seal it up and go
    Untitled by Corey S, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: What is this bolt?
    Dec 2016
    Texas
    Thanks for the help. I'm glad the oil leak turned out to be just a missing bolt that doesn't go to anything. Easy enough to replace.
  1. Cam Bolt
    By BoostedPontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2015, 08:56 PM
  2. Grand Prix vs Subaru WRX [Bolt ons] and Mitsubishi EVO [Bolt ons] [Videos]
    By ADrugDealer in forum Track Sessions and Kills
    Last Post: 05-06-2014, 12:02 PM
  3. Where did this bolt come from???
    By upsman72 in forum General Tech Discussion
    Last Post: 03-31-2012, 02:30 PM
  4. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  5. will this bolt right in?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-06-2010, 07:26 PM
