Thread: Noob Series III Supercharged Question
Results 1 to 9 of 9
  1. #1 Noob Series III Supercharged Question
    Jun 2016
    Colorado
    Hi all, I'm thinking about buying my second Grand Prix. My first was a 92 SE w/3.4L Twin Dual Cam. Great car, made 240,000 miles then stop and go LA traffic killed the tranny. Motor was still strong. My question today is about the 2005 GTP supercharged. I've read that the intake manifold gaskets are prone to failure. I read the WIkipedia page on the 3.8L, and it says only the N/A series III have the improved aluminum gasket - are the Series III Supercharged motor still using the plastic or is Wikipedia misleading? Are they really prone to fail? Thanks!
  2. #2 Re: Noob Series III Supercharged Question
    2005.5 ish was the switch over to aluminum intake gaskets for all 3800's.
    It's not that they are misleading, it's just not updated correctly.
    You'll have to check the car out to see what it has, it may have already been replaced by now too because the car is 11 years old.
  3. #3 Re: Noob Series III Supercharged Question
    Jun 2016
    Colorado
    Thanks, I'm still researching to see if there's anything else I should know before I scratch the check. Misleading probably wasn't the best word, just the way I read it, it sounded like they upgraded the N/A and not the supercharged, which would be weird.
  4. #4 Re: Noob Series III Supercharged Question
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    It's quite simple to change the gaskets if they are the plastic design, there's a few threads on it in the how to section.
    And welcome to GPF.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: Noob Series III Supercharged Question
    Jun 2016
    Colorado
    Quote Originally Posted by WarStryker13 View Post
    And welcome to GPF.
    Thanks for that - I found a video "Intake Gaskets in 33 Minutes". Thinking the obvious, I started the show. 6 minutes in, I stopped, because that was about a day's work for me! That How To section is extensive.
  6. #6 Re: Noob Series III Supercharged Question
    lim job is about a 4 hr job if you never did one before. once the fuel rail and the harness is unplugged its just nuts and bolts.
  7. #7 Re: Noob Series III Supercharged Question
    Oct 2014
    Frederick, MD
    I don't even pull the fuel line off, i just flip it up and set it on the windshield wipers. Lol
  8. #8 Re: Noob Series III Supercharged Question
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Two hours tops I think
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  9. #9 Re: Noob Series III Supercharged Question
    Jun 2016
    Colorado
    Thanks for all the input, but the GTP didn't make the cut. I fell for Bob (boring old Buick) instead. I got somebody's grampa's 2004 LeSabre Custom with the Series II N/A that really can't get out of it's own way. The upside was the mileage, 35K, and excellent condition. Since I'll probably need to replace those gaskets anyway, would supercharging this be easy?
  1. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  2. series i supercharged vs series 2 supercharged
    By 98grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2012, 04:03 PM
