Thread: how do i delete the evap system?
Results 1 to 17 of 17
  1. #1 how do i delete the evap system?
    SE Level Member Alexgp's Avatar
    May 2016
    Hermiston oregon
    just wanted to know how to delete the evap system on a 97 gtp?
  2. #2 Re: how do i delete the evap system?
    Remove everything EVAP related and turn off all the codes via a tuner.
  3. #3 Re: how do i delete the evap system?
    May 2016
    Hermiston oregon
    could I run it without a tune tho?
    97GTP3800
  4. #4 Re: how do i delete the evap system?
    May 2016
    Hermiston oregon
    what all is there the evap purge solenoid and evap canister anything else?
    97GTP3800
  5. #5 Re: how do i delete the evap system?
    It'll set a code
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  6. #6 Re: how do i delete the evap system?
    Quote Originally Posted by Alexgp View Post
    theres about 12 related codes for the evap. all sorts of dumb crap really. funny but they range from the p0400's all the way up to p1400's code numbers. aka codes all over the damn place.
  7. #7 Re: how do i delete the evap system?
    Buffalo
    I personally just removed whatever connected the system to the engine under the hood.
    Then waited to see what codes it popped.
    Removed those codes
  8. #8 Re: how do i delete the evap system?
    it will take time to become "ready" if you only delete the offending codes lol
    the only thing i need to wait to become ready is my up stream o2 sensor, cat, egr, evap and rear o2, all that craps gone. thats about 24 codes worth of deletion. lol
  9. #9 Re: how do i delete the evap system?
    May 2016
    Hermiston oregon
    I already have a evap purge solenoid code so I just wanna delete the system
    97GTP3800
  10. #10 Re: how do i delete the evap system?
    May 2016
    Hermiston oregon
    so on the the throttle body I just plug it up right?
    97GTP3800
  11. #11 Re: how do i delete the evap system?
    you need a tuned pcm then.
    yes, put a vac line cap on it.
  12. #12 Re: how do i delete the evap system?
    Buffalo
    stupid monitors. I'm waiting for the o2 heater to ready. Wtf
  13. #13 Re: how do i delete the evap system?
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    What do you do with the extra fuel line?
    02 sedan, top swap
  14. #14 Re: how do i delete the evap system?
    What extra fuel line?
  15. #15 Re: how do i delete the evap system?
    Dec 2010
    long prairie, mn
    I am referring to the tubing connected to the EVAP canister that runs parallel with the pressure and return fuel lines.
    02 sedan, top swap
  16. #16 Re: how do i delete the evap system?
    leave it there. why remove it all? just take it off the tb and its deleted, as long as all the codes are also deleted the cel wont pop up.
  17. #17 Re: how do i delete the evap system?
    SE Level Member b4black's Avatar
    Oswego, IL
    You're looking for the easiest solution, and since you don't have a tuner, the easiest solution is to read the code and fix the problem. There's no benefit to removing the EVAP and deleting properly is a can of worms.
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  1. Evap Delete?
    By adl2494 in forum General Tech Discussion
    Last Post: 12-17-2013, 02:35 AM
  2. Another EVAP Delete Thread
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2012, 10:51 PM
  3. EVAP delete
    Last Post: 11-05-2011, 03:06 PM
  4. evap delete
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2011, 02:35 PM
  5. Delete EVAP code
    By Deathsports in forum PCM Tuning
    Last Post: 11-09-2010, 04:17 PM
