Thread: 2008 grand prix abs problem
Results 1 to 3 of 3
  1. #1 2008 grand prix abs problem
    Nov 2013
    pittsfield ma. 01201
    When I turn my wheels to the left and hit the brakes my abs kick in but gives no fault codes and the abs light not coming on.Did a scan of abs system no fault codes showing.
  2. #2 Re: 2008 grand prix abs problem
    Can it do live data with each wheel??
    I'd try to make it do it and see if a wheel is dropping out and causing the ABS to engage. Alot of times once you are under 5-10mph you can see what wheel just drops to zero on the scanner.
  3. #3 Re: 2008 grand prix abs problem
    Nov 2013
    Ok thanks will give it a try
  1. 2008 Grand Prix Door Lock Problem
    By SMac68 in forum General Tech Discussion
    Last Post: 11-21-2017, 10:59 PM
  2. 2008 Grand Prix...problem?
    By BowTie in forum General Tech Discussion
    Last Post: 01-13-2011, 06:27 PM
  3. 2008 Grand Prix headlight problem
    By buckwheat in forum General Tech Discussion
    Last Post: 09-04-2010, 09:36 AM
  4. New Here-2008 Grand Prix
    By aricshep in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 10:59 PM
