Thread: 2008 Grand Prix headlight problem
Results 1 to 5 of 5
  1. #1 2008 Grand Prix headlight problem
    Jul 2010
    a van down by the river
    Hi everyone,
    My daughter has a 2008 Grand Prix with a headlight problem. Last night the headlights quit working while she was driving. I checked the fuse etc and found no problem. I thumped the switch a few times and switched them from auto to 'on' and they came on. A friend told her the problem is the daytime sensor switch that is on the steering column under the bezel. He said it is a common problem and the switch costs about 120 from auto zone or wherever. Has anyone else had this happen? The car only has 24k on it, wouldn't expect something like this to happen already ...
  2. #2 Re: 2008 Grand Prix headlight problem
    SE Level Member wrngway's Avatar
    I just did a search to TSB's. I didn't find any, though I only have access to TSB's for the 2004 Grand Prix. That's the first I've heard of the problem.
    I'm no expert, but if they only come on in the "on" postion and not "auto", assuming it's dark outside, than yes, I'd agree may have something to do with the sensor. Either that or the headlight switch.
    2004 Grand Prix GTP
    GMPP Rear Sway Bar, Trailing Arms, F & R STB's, 180stat, Wizzair, Overkill PCM, SD Headers, EGR Blocked
  3. #3 Re: 2008 Grand Prix headlight problem
    Jul 2010
    Portland, Oregon
    Did you get this problem fixed? I am having the same problem and as I write, the car is at the dealer, and they have no clue as to why this is happening. I only had high beam and both low were out. Sensor? Switch?
  4. #4 Re: 2008 Grand Prix headlight problem
    Jul 2010
    Hi Wiley,
    The problem is still there but has somewhat cleared up. I think it is a loose connection or faulty switch within the steering column or multifunction switch. I personally have only seen it happen once and after turning the switch on and off a few times and thumping the column with my hand the lights came back on. Both my daughter and her boyfriend have said it happens after you hit a bump in the road...
  5. #5 Re: 2008 Grand Prix headlight problem
    Jul 2010
    Portland, Oregon
    Thanks Buckkwheat. My problem was finally traced to the sensor in the dash.
    $115.00 and problem solved.
  1. 2008 Grand Prix GXP 5.3L
    By toolman in forum Introductions/Noob Questions
    Last Post: 05-17-2010, 06:30 AM
  2. New Here-2008 Grand Prix
    By aricshep in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 10:59 PM
  3. 2008 Grand Prix
    By firehawk in forum General Tech Discussion
    Last Post: 11-24-2008, 06:43 PM
  4. 2008 grand prix
    By KingOfTheSouth in forum Off Topic Discussion
    Last Post: 11-05-2008, 07:47 AM
