Thread: Car shuts off when I slow down or brake
Results 1 to 7 of 7
  1. #1 Car shuts off when I slow down or brake
    Aug 2014
    United States
    So lately I've been having a lot of fuel issues with my 97 GTP. Now when I'm driving and I slow down or brake the car shuts off and the battery and oil light come on. No CEL. Let's say I'm cruising on a regular street and take my foot off the gas the car feels like it's going to shut off, no drone, no nothing. But the biggest issues is the stall. What could be the issue
  2. #2 Re: Car shuts off when I slow down or brake
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    There was a video I saw on YouTube awhile back with a car that had similar problems. It turned out there was a large vacuum leak that would cause the car to stall out in the right conditions. Take some carb cleaner and spray all around the throttle body and edge of the upper intake manifold. If you hear the idle change (do this with the car running), then you have a vacuum leak.
  3. #3 Re: Car shuts off when I slow down or brake
    A possible failing crank sensor could be the cause aswell.
  4. #4 Re: Car shuts off when I slow down or brake
    Aug 2014
    United States
    I just replaced the crank sensor on Friday
    Sent from my SM-G900V using Tapatalk
  5. #5 Re: Car shuts off when I slow down or brake
    Apr 2015
    Try what I mentioned above with carb cleaner. Start with simple stuff.
  6. #6 Re: Car shuts off when I slow down or brake
    Antioch, IL
    IAC? my truck acted like this, had to keep on the throttle and harder on the brakes until I replaced it.
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Car shuts off when I slow down or brake
    Aug 2014
    United States
    So car is back working now but the car is leaking out oil pretty bad. Especially when I start it... and there's smoke coming from behind the engine my guess is the valve cover gasket but ugh it's always something lol
  1. Turn the Key - Everything Shuts Off
    By CNorell145 in forum General Tech Discussion
    Last Post: 03-19-2015, 10:15 PM
  2. 02 Starts and then Shuts Off?
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2013, 12:20 PM
  3. Replies: 21
    Last Post: 08-30-2010, 07:41 PM
  4. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  5. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
