Get the 00-05 rotors to fit on what bracket booba? I used the 00-05 Impala Bracket as outlined in my writeup, which bolts to the hub and allows for you to use the 00-05 rotors, which are the same size as fbody rotors, the ones on my car are actually fbody rotors, it all bolted up fine and works without turning the rotors, or doing any grinding, literally bolt on brackets, put on rotors, bolt stock caliper to bracket, use pads for grand prix and you're on your way.
